093-404_ALT_0
093-404_ALT_1
Switchcraft EHRCA2BX RCA Feedthru Jack Connector Black w/4-40 Screw
Brand:| Model: EHRCA2BX
Product Video
The EHRCA2BX is a bulkhead RCA feedthru jack EH Series panel mount connector and features a zinc die-cast housing with black chrome finish.
093-404
Weight: 0.1 lbs.
IN STOCK
List Price$12.99
You Save37%
$8.18
Buy 10-up$7.76
Part # 093-404
The EH Series by Switchcraft® is a complete line of audio, video, and data connectors built into standard panel-mount XLR housings. Custom combinations of EH Series connectors can be quickly loaded into any of Switchcraft's Q-G® Series panels. Once mounted, connecting your equipment to the back of an EH Series connector is fast and easy. Most connectors are feedthru, which means standard cabling is simply plugged into the back of your gear, then plugged into the back of the EH Series connector. For those EH Series connectors that are not feedthru, solder lugs are clearly marked for simple, secure solder connections. All EH Series connectors come individually bagged with #4-40 mounting screws. The EHRCA2BX is a bulkhead RCA feedthru jack EH Series panel mount connector and features a zinc die-cast housing with black chrome finish.
Specifications: • Contact plating: nickel • Sold per: each • Finish: black  • Dimensions: 1.87" x 1" x 1.19"
  • GenderFeedthrough
  • Mounting TypeChassis / Panel Mount
  • BrandSwitchcraft
  • ModelEHRCA2BX
  • Part Number093-404
  • UPC844632072031
  • Product CategoryRCA Connectors
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the Switchcraft EHRCA2BX RCA Feedthru Jack Connector Black w/4-40 Screw
in the RCA Connectors product category.
Switchcraft EHRCA2BX RCA Feedthru Jack Connector Black w/4-40 Screw is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Great connectorI wish it wasn't quite so expensive, but this is a great connector that I use on all the equipment I build.It uses a standard 1" hole size, which is the same size used by the XLR and SpeakOn connectors I use. It's great that I can put this in a piece of equipment, and if I want to switch to XLRs later, I can use the same chassis, without modification. (Of course the internals will need to change to handle the balanced connection.)Because of the construction of this connector, there's also no question that there's plenty of insulation between the shield of the connector and chassis, so no need to worry about ground loops.
Date published: 2010-03-03
  • 2015-03-27T08:09CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_093-404, PRD, sort_mostRecent
Videos
Customer projects that include: Switchcraft EHRCA2BX RCA Feedthru Jack Connector Black w/4-40 Screw
