093-148_ALT_0
093-148_ALT_1
Switchcraft 3502A RCA Plug Connector Nickel
Brand:|Model: 3502A|Part # 093-148
Switchcraft's 3502A RCA cable mount plugs have a nickel body with 2 nickel connectors. A solder cup is located on center conductor for fast, easy termination.
OUT OF STOCK
Due In: 8/5/2016
List Price$2.37
You Save16%
$1.98
Buy 10-99 $1.65
Buy 100+$1.55
Part # 093-148
  • Solder cup on center conductor for fast, easy termination
  • Solid center conductor
  • High quality appearance
  • Larger cable clamp provides better strain relief for larger cables
  • Longer cable clamp for easier plug assembly and more room for solder connection
  • Knurl on the back of handle provides ergonomic gripping surface to tighten plug
  • Longer handle for improved gripping surface and easy plug withdrawal from jack
Switchcraft's 3502A RCA cable mount plugs have a nickel body with 2 nickel connectors. A solder cup is located on center conductor for fast, easy termination. Larger cable clamp provides better strain relief for larger cables. Heavy duty cable clamp and removable handle accepts cables up to .203" (5.16 mm) diameter. Features include solid pin, shielded handle, and large cable clamp. Terminals may be crimped with pliers for temporary connections or soldered for permanent connections. Plug accommodates multiple jacks spaced on .438" (11.13 mm) centers. Switchcraft phono jacks and plugs are recommended for semi-permanent connections in audio and electronic applications. Mfg. #3502A.
Specifications: • Shell: nickel • Contact plating: nickel • Sold per: each • Finish: nickel • Termination style: solder • Entry hole: 5.6 mm • Dimensions: 0.37" x 1.20"
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • BrandSwitchcraft
  • Model3502A
  • Part Number093-148
  • UPC844632071751
  • Product CategoryRCA Connectors
    (11 Reviews)
  • Weight0.025 lbs.
View similar products to the Switchcraft 3502A RCA Plug Connector Nickel
in the RCA Connectors product category.
