Svetlana SV811-10 Vacuum Tube Duet Platinum Matched
Brand:|Model: SV811-10|Part # 072-517
The Svetlana SV811-10 audio power amplifier triode is intended for use in class A, AB, or class B amplifiers. It features a directly heated thoriated tungsten filament for the warm sound and warm glow of this classic form of cathode.
ORDER TODAY
Ships in 7-10 Business Days
List Price$212.00
You Save30%
$149.38
Buy 6+$137.90
Part # 072-517
The Svetlana SV811-10 audio power amplifier triode is intended for use in class A, AB, or class B amplifiers. It features a directly heated thoriated tungsten filament for the warm sound and warm glow of this classic form of cathode. Thoriated tungsten filaments allow the SV811-10 series to handle overdrive at a cleanly defined level unlike commonly used oxide cathodes. Thoriated tungsten filaments are exceptionally stable and are not process sensitive. Therefore, their performance is much less adversely affected by overload. They also provide significantly better sound over a longer lifetime than oxide cathodes. The internal tube parts are supported by ceramic insulators for high-temperature operation and high voltage hold-off. Stressed mica supports are used against the envelope to absorb vibration, thus controlling microphonic effects. The internal structure is aligned with respect to the base pins to avoid internal shorts if the tube is operated in a horizontal position. Because these tubes are generally installed on the outside of high-end audio amplifiers, Svetlana manufacturing controls external mechanical and visual characteristics in addition to electrical characteristics. Further, Svetlana has incorporated a bright glazed white ceramic base which contributes significantly to the overall classic appearance of the SV811-10. The platinum matching process consists of a 24 hour tube burn-in period followed by a bias current measurement.
PRODUCT SPECIFICATIONS
  • Tube TypePower Tubes
  • MatchingMatched Pair
  • BrandSvetlana
  • ModelSV811-10
  • Part Number072-517
  • UPC844632022029
  • Product CategoryVacuum Tubes
  • Weight0.75 lbs.
Peavey 12AU7 Tube (Each)
Part #  248-8826
Electro-Harmonix 6L6 EH Vacuum Tube
Part #  072-830
Peavey EL 84 Tubes (2 Per)
Part #  248-8824
View similar products to the Svetlana SV811-10 Vacuum Tube Duet Platinum Matched
in the Vacuum Tubes product category.
