309-148_ALT_0
Surface Transducer Turns Virtually Anything Into A Speaker
Brand:|Part # 309-148
These 25mm OEM grade transducers (also known as exciters) were originally used in Marcato outdoor audio systems. When attached to any surface, transducers will convert virtually anything into a "sound board".
Comparable Items In Stock:
Part # 309-148
  • Turn any solid surface into a great sounding speaker system
  • Create a completely hidden surround sound system
  • Wideband frequency response (dependent on attached material)
These 25mm OEM grade transducers (also known as exciters) were originally used in Marcato outdoor audio systems. When attached to any surface, transducers will convert virtually anything into a "sound board". Test your transducer on a variety of surfaces. Once you have decided where to place the transducer, you will need to glue it down. We recommend a gel type glue, available from Parts Express. The glue will allow you to permanently mount your transducers. To properly glue, place a small bead/dots on the transducer feet pads and around the edge of the voice coil. It's extremely important that you are sure of the mounting location, as removal of the transducer after mounting may permanently damage the device. After applying the glue on the transducer feet, take a small cloth, dab with the gel type glue and wipe around the edge of the voice coil. Place the exciter on the surface and position for optimum performance, press and hold. After 20 seconds the glue will be hardened and the exciter sticks to the panel. Transducer pair comes with a 6dB high pass filter, wired in serial for 8 ohm applications. Units can be separated and used individually. Glue not included. Transducer Specifications: • Power handling: 10W RMS • Impedance: 4 ohms • VCdia: 1" • Dimensions: 3-1/2" dia. x 3/4".
  • Impedance4 ohms
  • Power Handling (RMS)10 Watts
  • BrandFactory Buyouts
  • Part Number309-148
  • UPC844632081545
  • Product CategoryExciters & Tactile Transducers
  • Unit of MeasurePR
    (26 Reviews)
  • Weight0.4 lbs.
View similar products to the Surface Transducer Turns Virtually Anything Into A Speaker
in the Exciters & Tactile Transducers product category.
