Sure Electronics RGB 30 LED 1m Strip with Controller 12 VDC
Brand:|Model: DC-LE11124|Part # 073-074
Create your own custom lighting with this RGB LED strip. An 83 program LED controller is included and features 10 levels of speed control per program and individual LED control.
  • 30 RGB LEDs with an 83 function controller
  • Longer life and lower power consumption compared to rope lights
  • Weatherproof for outdoor use
This 1 meter (3.28 feet) RGB LED strip is built with bright surface mount RGB LEDs and offer amazing color density. Great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each strip.
The included controller creates amazing light shows featuring 83 different programs with 10 levels of speed control for each program. The controller features a phoenix-type quick disconnect connector for easy wiring. Simply connect a 12 VDC power supply (up to a 12 VDC, 1A power supply is recommended and sold separately) and go!
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 750 mA • Overall dimensions: 0.67" W x 39.36" L x 0.125" H (17 x 1000 x 3 mm).
RGB LED Specifications: • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
Note: This controller is designed to work with only this RGB LED strip. Other strips will not operate with this controller in the same manner.
  • BrandParts Express
  • ModelDC-LE11124
  • Part Number073-074
  • UPC844632093715
  • Product CategoryAccent & Party Lighting
  • Weight0.6 lbs.
View similar products to the Sure Electronics RGB 30 LED 1m Strip with Controller 12 VDC
in the Accent & Party Lighting product category.
