073-070_ALT_0
073-070_ALT_1
073-070_ALT_3
073-070_ALT_4
073-070_ALT_5
073-070_ALT_6
073-070_ALT_7
073-070_ALT_8
073-070_ALT_9
Sure Electronics RGB 30 LED 0.5m Tape Lighting Strip 12 VDC Waterproof IP65
Brand:| Model: DC-LE12115
Product Video
Create your own custom lighting with RGB LED tape strips. Pre-applied 3M adhesive attaches to almost any surface and the sealed design is impact resistant and weatherproof. This 19.68" long strip features 30 RGB LEDs and can be cut to custom lengths.
  • 15 LEDs with seven different color combinations
  • Longer life and lower power consumption compared to rope lights
  • Connects to LED remote control units for custom effects
  • Cut lines on circuit board for creating miniature segments
  • Impact resistant and weatherproof for outdoor use with adhesive backing
073-070
Weight: 0.1 lbs.
IN STOCK
List Price$14.99
You Save33%
$9.97
Buy 4-up$9.47
Part # 073-070
These LED tape strips are built with 3 bright surface mount RGB LEDs per every segment for amazing color density. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each strip. Aggressive adhesive to affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to four miniature 3.94" strips with three RGB LEDs per section. Each section features four solder points (voltage +, green, red, and blue) to create one of seven different colors and for easy daisy-chaining.
To facilitate ease of use, Sure Electronics has built-in voltage dropping resistors. Simply connect a 12 VDC power supply (up to a 12 VDC, 3A power supply is recommended and sold separately) to the solder points (see wiring diagram in Manuals/Resources section on the right) and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Pre-terminated with a 5" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant and IP65 rated (no ingress of dust; complete protection against contact. Water projected by a nozzle (6.3mm) against enclosure from any direction shall have no harmful effects).
Note: Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 600 mA • Overall dimensions: 0.44" W x 19.68" L x 0.125" H (11 x 500 x 3.2 mm) • Segment dimensions (roughly seven segments per strip): 3.94" L (100 mm).
RGB LED Specifications: • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
  • BrandSure Electronics
  • ModelDC-LE12115
  • Part Number073-070
  • UPC844632093692
  • Product CategoryAccent & Party Lighting
    (2 Reviews)
  • Weight0.1 lbs.
View similar products to the Sure Electronics RGB 30 LED 0.5m Tape Lighting Strip 12 VDC Waterproof IP65
in the Accent & Party Lighting product category.
Sure Electronics RGB 30 LED 0.5m Tape Lighting Strip 12 VDC Waterproof IP65 is rated 2.5 out of 5 by 2.
Rated 3 out of 5 by from Great for first time led projectThis is my first try at adding some led lights around the house. Easy to use and power. My only complaint is they were wound to tight in the packaging and the protective rubber is split in a few spots.
Date published: 2012-12-29
Rated 2 out of 5 by from sadly disappointedI have ordered LEDs from other companies before and everything has come great. However the led strips come so tightly wound and placed in such a small box that the leds start to pull away from their solder connections causing weird color patterns and sometimes altogether quit. Also the water protection on the strip comes cracked and when you unroll it the silicone upper layer peels off. This could be a great product if they fixed their packaging problems. I bought 2, 1/2 meter strips both of which were damaged right out of the box and 3, 1 meter strips. The 1 meter strips were placed in a slightly larger box. I happened to get lucky and none of the leds were damaged however the silicone layer on top was still cracked and immediately wanted to start peeling off as soon as I straightened it out.
Date published: 2011-10-31
  • 2015-07-29T07:16CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_073-070, PRD, sort_mostRecent
I want to be able to put one strip in each foot well of my car. So I was wondering how would I do that without having two different power sources and how I would set them up on my car so they work.
Asked by: carjunky
You can cut the strips and run bare wire from the controller to where the light strip starts. You only need one power supply. The LED strips run on 12vdc so you will need to connect them to your battery through the ignition switch or use an 12vdc inverter plugged into your lighter.
Answered by: TomI
Date published: 2015-02-02
Can u use this in a car or house? if so any converters needed
Asked by: xllsc
You can use this in your car as is.( your cars voltage is 12v)If you want to use this product in your home, you'll need a 12v transformer. you can get one at any radio shack or hobby shop.
Answered by: audio freek
Date published: 2012-02-21
How Many strips can be connected together? What is the maximum length using one of the controllers?
Asked by: mromoaudio
Each control unit will handle up to 5m of LED strips. As long as you have one controller for each 5m length, there is really no limit to how many strips can be used.
Answered by: RussR
Date published: 2013-09-09
  • 2015-07-29T08:28CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_073-070, PRD, sort_recentQuestionsFirst
Videos
Customer projects that include: Sure Electronics RGB 30 LED 0.5m Tape Lighting Strip 12 VDC Waterproof IP65
