073-075_ALT_0
073-075_ALT_1
073-075_ALT_2
073-075_ALT_3
073-075_ALT_4
073-075_ALT_5
073-075_ALT_6
073-075_ALT_7
073-075_ALT_8
073-075_ALT_9
Sure Electronics RGB 150 LED SMD 5050 5m (16 ft.) Tape Lighting Strip 12 VDC Waterproof IP65
Brand:|Model: DC-LE12118|Part # 073-075
Create your own custom lighting with RGB LED tape strips. Pre-applied adhesive attaches to almost any surface and the sealed design is impact resistant and weatherproof. This 196.8" (5 meter) long strip features 150 RGB LEDs and can be cut to custom lengths.
Comparable Items In Stock:
Part # 073-075
  • 150 LEDs with seven different color combinations
  • Longer life and lower power consumption compared to rope lights
  • Connects to optional LED remote control units for custom effects
  • Aggressive adhesive backing for permanent mounting
  • CE and RoHS compliant, IP65 rated
  • Great for use as holiday lighting, indoor accent lighting... even in automotive applications!
RGB LED tape strips are built with 3 bright surface mount RGB LEDs per every 4" for great color density. These strips are great for use as indoor strip lighting or illuminating a display case. Aggressive adhesive is affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 49 miniature 4" strip segments with three RGB LEDs per section. Each section features four solder points (voltage +, green, red, and blue) to create one of seven different colors and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the solder points (see wiring diagram in Manuals/Resources section on the right) and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Each strip is pre-terminated with a 4" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant, IP65 rated to prevent dust ingress and short periods of immersion in water.
Note: Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • CE and RoHS compliant • IP65 rated • Overall dimensions: 0.44" W x 196.80" L x 0.125" H (11 x 5000 x 3.2 mm) • Segment dimensions (49 segments per strip): 4" (101.6 mm) L.
RGB LED Specifications: • LED type: SMD 5050 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
  • BrandParts Express
  • ModelDC-LE12118
  • Part Number073-075
  • UPC844632096754
  • Product CategoryAccent & Party Lighting
    (1 Reviews)
  • Weight0.54 lbs.
View similar products to the Sure Electronics RGB 150 LED SMD 5050 5m (16 ft.) Tape Lighting Strip 12 VDC Waterproof IP65
in the Accent & Party Lighting product category.
Videos
