Sure Electronics Red LED 7-30 VDC Panel Meter
Brand:|Model: ME-DV41331
Monitor stored batteries and DC voltages on a circuit quickly with this panel meter.
List Price$14.99
You Save41%
$8.90
Buy 4+$8.46
Part # 320-532
  • Monitor stored batteries
  • Works off battery voltage
  • Low power consumption
  • Auto-brightness conserves power consumption
  • Easy to read 0.56" LED display
Measure DC voltages from 7 to 30 VDC quickly and accurately with this panel meter. Perfect for monitoring stored vehicle or tool batteries, three 7-segment red LEDs indicate voltage without requiring a separate power supply. 8" probe cable included.
Specifications: • Power requirements: 7 to 30 VDC • Power consumption: 36 mA (@ 12 VDC) • Display type: 3-2/3 digits • Range: 7 to 30 VDC • Accuracy: ± 0.15 VDC • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
  • BrandSure Electronics
  • ModelME-DV41331
  • Part Number320-532
  • UPC844632093319
  • Product CategoryPanel Meters
    (3 Reviews)
  • Weight0.25 lbs.
View similar products to the Sure Electronics Red LED 7-30 VDC Panel Meter
in the Panel Meters product category.
Sure Electronics Red LED 7-30 VDC Panel Meter is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Great Product, Great PriceThis is an easy to use volt meter. Simply connect the positive and negative leads to a voltage source and it will display an easy to read value.Do not use if you are looking for an extremely accurate reading. I find that there is an error up to 0.8-1 volt compared to the reading on my true RMS reading on a Fluke volt meter. Mind you, the error is not always this big, but it can be.For a quick general reading though, it is a great meter
Date published: 2013-05-14
Rated 5 out of 5 by from Well worth itVery good price!When I buy these, I buy four at a time.Works great!My shed in the backyard doesn't have electric so I installed a 12v lead acid battery with a switch next to the door to turn on the light bulb. I connected the meter to turn on with the light so can see the voltage of the battery. This way I can keep an eye on the voltage status needing a charge.
Date published: 2012-05-20
Rated 5 out of 5 by from big display, small packageThis unit has a very legible display. I have a 12V service feed into my office from my solar-charged battery bank. I wanted a battery voltage display that I could read from anywhere in the room. This unit looked like it would do the job and the price was right, so I ordered one.The unit is designed to be mounted in a metal panel in a 2.875 x 1.625 square hole. The locking tabs require a slight notch (about 1mm) on either end of the hole. Once you have a correctly sized hole, the unit locks in with plastic tabs. Since I was mounting it on the wall, I used part of a hard drive mounting bracket from an old PC to make a mount.Once it's mounted, installation is simple, and the unit performs as advertised. It will even work on a 6V battery (I played with it for a while, before I installed it). It is a very flexible unit.
Date published: 2012-01-10
  • 2015-09-05T06:22CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_320-532, PRD, sort_mostRecent
