Clearance Item
073-006_ALT_0
073-006_ALT_1
Sure Electronics Quadcolor RGBY LED Tester/Driver Board
Brand:| Model: LE-LL21119
Quickly connect and test Sure Electronics' RGBY quadcolor LED boards with this tester/driver board from Sure Electronics.
  • Acts as both a test and driver for quadcolor RGBY boards
073-006
Weight: 0.2 lbs.
This LED test board acts as both a controller and driver for Sure Electronics' quadcolor RGBY LED boards via an 8-pin output connector (female to female cable included). Once 12 VDC is applied, the test board cycles through one of four colors testing both operation and brightness control. A button is mounted on the test board to manually cycle through colors.
Specifications: • Power requirement: 12 VDC, 2A • Power jack: 2.1 mm ID. x 5.5 OD • Dimensions: 1.875" (47.63 mm) W x 3.5 " (90 mm) L.
  • BrandParts Express
  • ModelLE-LL21119
  • Part Number073-006
  • UPC844632093371
  • Product CategoryHigh-Power LED Assemblies
  • Weight0.2 lbs.
View similar products to the Sure Electronics Quadcolor RGBY LED Tester/Driver Board
in the High-Power LED Assemblies product category.
Customer projects that include: Sure Electronics Quadcolor RGBY LED Tester/Driver Board
