320-3140_ALT_0
Sure Electronics PS-SP11184 24 VDC 8.8A 200W Regulated Switching Power Supply
Brand:|Model: PS-SP11184|Part # 320-3140
This large 24 volt DC, 8.8 amp regulated power supply is capable of up to 200 watts of output. Switchable 90-264 volts AC input. UL recognized design.
List Price$64.99
You Save34%
$42.90
Buy 4+$40.25
Part # 320-3140
  • Adjustable 20 to 26.4 VDC regulated output with 8.8A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Great for electronics projects, especially amplifiers
  • For use with electronics that demand up to 200 watts of power
This beast of a power supply is ideally suited for use with amplifier projects. With a regulated output of 24 volts DC, and current capacity of 8.8 amps, this power supply is the perfect partner for amplifier boards with of up to 200 watts of output on tap.
Voltage input can be switched for use with 110 or 240 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Power cable included. UL recognized design. Output voltage is adjustable from 20 to 26.4 VDC.
Note: Minimum recommend power wire gauge is 16 AWG.
Specifications: • Input power: Switchable between 90-132 VAC and 180-264 VAC, 47-63 Hz • Output power: 24 VDC, 8.8A • Dimensions: 7.83" L x 4.41" W x 2" H.
  • BrandSure Electronics
  • ModelPS-SP11184
  • Part Number320-3140
  • UPC848864002781
  • Product CategoryPower Supplies
  • Weight2.05 lbs.
View similar products to the Sure Electronics PS-SP11184 24 VDC 8.8A 200W Regulated Switching Power Supply
in the Power Supplies product category.
I have an odd use case where I would connect an 8 Ohm speaker to the left channel and a 4 Ohm speaker to the right channel.  Will that present any issues with the amp?
Asked by: 99alex
The Sure Electronics PS-SP11184 is a power supply, not an amplifier. Please contact our tech support for any additional help with this question, tech@parts-express.com or 800-338-0531 x1.
Answered by: GregT
Date published: 2016-02-11
Are the two cables pictured included with the power supply?
Asked by: Tiercel2012
Yes these cables are included with the power supply.
Date published: 2014-08-27
  • 2016-02-14T07:52CST
  • loc_en_US, sid_320-3140, PRD, sort_recentQuestionsFirst
