Sure PS-SP11182 12 VDC 4.3A 50W Regulated Switching Power Supply
Sure Electronics PS-SP11182 12 VDC 4.3A 50W Regulated Switching Power Supply
Brand:|Model: PS-SP11182|Part # 320-3147
This 12 volt DC, 4.3 amp regulated power supply is capable of up to 50 watts of output. 85 to 264 volts auto-sensing AC input. UL recognized design.
List Price$34.99
You Save32%
$23.90
Buy 4+$22.90
Part # 320-3147
  • Adjustable 10.8 to 13.2 VDC regulated output with 4.3A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Great for electronics projects, especially amplifiers
  • For use with electronics that demand up to 50 watts of power
  • Auto-sensing AC input works with 85 to 264 VAC
This power supply is ideally suited for use with amplifier projects. With a regulated output of 12 volts DC, and current capacity of 4.3 amps, this power supply is the perfect partner for amplifiers with of up to 50 watts of output on tap.
Auto-sensing voltage input for use with 85 to 264 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Power cable included. UL recognized design. Output voltage is adjustable from 10.8 to 13.2 VDC.
Note: Minimum recommend power wire gauge is 16 AWG.
Specifications: • Input voltage: 85~264 VAC, 50/60 Hz • Output voltage: 12V 4.3A; 10.8~13.2V adjustable • Dimensions: 5.08" L x 3.86" W x 1.50" H.
This 12 volt DC, 4.3 amp regulated power supply is capable of up to 50 watts of output. UL recognized design.
  • BrandSure Electronics
  • ModelPS-SP11182
  • Part Number320-3147
  • UPC848864002682
  • Product CategoryPower Supplies
    (2 Reviews)
  • Weight1.06 lbs.
View similar products to the Sure Electronics PS-SP11182 12 VDC 4.3A 50W Regulated Switching Power Supply
in the Power Supplies product category.
Sure Electronics PS-SP11182 12 VDC 4.3A 50W Regulated Switching Power Supply is rated 3.0 out of 5 by 2.
Rated 5 out of 5 by from Works GreatThis has worked excellent, and has powered my small projects well
Date published: 2015-02-11
Rated 1 out of 5 by from 2 bad units so farSays it is switchable for AC volts in but even after I opened up the case I find no switch. So far $50 spent no DC out from either power supply. I am not ahappy camper.
Date published: 2014-03-11
  • 2016-02-07T06:31CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_320-3147, PRD, sort_mostRecent
Can I use this to power both a board that requires +12v/-12V and also one that requires just +12v? Both drawing less than 2A.
Asked by: jboog900
Date published: 2015-07-09
could I use this to power a 12 volt CB radio in my work shop for 6 to 8 hours a day
Asked by: cajunmal66
Yes as long as the radio doesn't draw more than 4 amps under load.
Date published: 2015-05-22
I just received this and it's great. I'm using it with 3 unbalanced to balanced direct boxes. the wall warts that they came with were totally horrible. One question, the unit came with a dc power cord, what size dc plug is on the cord so I can buy more
Asked by: Rosekoi2
This includes a 2.1mm x 5.5mm DC power cord.
  • 2016-02-07T07:26CST
  • loc_en_US, sid_320-3147, PRD, sort_recentQuestionsFirst
