Sure Electronics LE-LL19113 High Power RGB LED Control Unit with 24-Key IR Remote
Brand:|Model: LE-LL19113|Part # 073-005
This high power RGB LED control unit, with IR controller, offers nearly unlimited potential for the use of RGB LED strip lighting (or up to 3 different single-color LED strips). You can also sync multiple control units together for increased area coverage. Includes 24-key IR remote control.
List Price$59.99
Regular Price$32.95
You Save15%
Sale Price
$27.95
Sale Ends9/30/2016
Part # 073-005
  • Control up to 49 feet of LED strip lighting (RGB or 3 different colors)
  • Link multiple controllers together—up to 164 feet apart!
  • Includes 24-key IR remote control
  • Adhesive backed and includes screws for permanent mounting
  • Requires power supply
This high power RGB LED control unit allows you to power and control up to 49 feet (15 meters) of RGB LED strips on a single run. Additionally, multiple controllers can be daisy-chained and synced together using the built-in data bus, for single control over multiple LED strips. The maximum length of the data bus is 164 feet (50 meters), and provides an amazing amount of area coverage. Each controller requires its own power supply.
A 24-key infrared remote control is included for quickly powering LED strips on or off, changing through one of 16 different colors, controlling brightness, or for using one of the four built in color loop modes: flash (a 7-color flashing loop), strobe (3-color strobe loop), fade (7-color quick fade), or smooth (7-color smooth fade).
Also, this controller features a function control button for local function changes, and is designed to work with both 12 VDC and 24 VDC LED strips (do not mix strip voltages), and can alternatively power up to three different single-color strips on a single controller. Adhesive has been pre-mounted on the back of the controller for permanent placement, and two mounting screws are included. IR remote control uses a single CR2025 battery (battery included), see Related Items for replacements.
Note: Only use the correct power supply for the stated LED strip voltage. Please refer to the LED strip packaging or manufacturer prior to connecting power supply to controller. Never link the LED outputs of multiple controllers together. Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings. For consistent color brightness wire each strip in parallel directly to the controller.
• Input power (maximum): 12 VDC, 15A or 24 VDC, 15A
• Output power (maximum): 180W (12 VDC), 360W (24 VDC)
• Output power per color (maximum): 60W (12 VDC), 120W (24 VDC)
• Control unit dimensions: 4.76" L x 2" W x 1.02" H
• IR remote control range: 23 ft. (7 meters)
  • BrandSure Electronics
  • ModelLE-LL19113
  • Part Number073-005
  • UPC848864000251
  • Product CategoryAccent & Party Lighting
    (3 Reviews)
  • Weight0.55 lbs.
