Sure Electronics LE-LL19112 44-Key LED Control Unit with IR Remote Control
Brand:|Model: LE-LL19112|Part # 073-004
Designing your custom lighting solution is made easy with this 44-key LED control unit. An IR remote control is included for remote operation.
List Price$14.99
You Save33%
Buy 4+$9.47
Part # 073-004
  • Great for product displays or window treatments
  • Drives up to 5 meters of 12 VDC RGB LED strips
  • IR remote control included
  • 6 memory locations
Create custom lighting effects with this 44-key IR remote control and LED control unit, that's specifically designed to work with 12 VDC RGB LED light strips. Adjust brightness, color, fade in/out, and flash rate. Supports up to five meters of RGB LED light strips. Other tri-color, common anode LEDs may be used if configured to work with 12 VDC supply voltage by the use of voltage dropping resistors. IR remote control uses a CR2025 battery (included). Requires 12 VDC power supply (not included).
Specifications: • Power requirements: 12 VDC, 2A (minimum recommended), 12 VDC, 6A (with max current draw from each of three LEDs) • Power input: 2.1 x 5.5 mm, center positive • Output: Three CMOS drain-open output • Connection type: Common anode • Control unit dimensions: 63 mm (2.48") L x 35 mm (1.38") W x 22 mm (0.87") H.
Note: To use the DIY memory keys, press the desired memory key, use the up/down red, green, or blue arrows to adjust to desired color, then press the DIY memory key again to store the color. Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)Pause/RunOn/Off
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark blueStatic off-white
Static dark yellowStatic cyanStatic royal blueStatic light pink
Static yellowStatic light blueStatic pinkStatic green white
Static light yellowStatic sky blueStatic brownStatic blue white
Increase redIncrease greenIncrease blueSpeed up
Decrease redDecrease greenDecrease blueSpeed down
Memory 1Memory 2Memory 3Automatic change
Memory 4Memory 5Memory 6Flash on and off
3 color change7 color change3 color fade change7 color fade change
  • BrandSure Electronics
  • ModelLE-LL19112
  • Part Number073-004
  • UPC844632093364
  • Product CategoryAccent & Party Lighting
    (5 Reviews)
  • Weight0.15 lbs.
