Sure Electronics LE-LL19111 24-Key LED Control Unit with IR Remote Control
Brand:|Model: LE-LL19111|Part # 073-002
This LED control unit allows you to create effects that are limited only by your imagination. Designed to work with up to 5 meters of RGB LED light strips.
List Price$9.99
You Save40%
$5.98
Buy 4+$5.68
Part # 073-002
  • Great for product displays or window treatments
  • Drives up to 5 meters of RGB LED strips
  • IR remote control included
Create custom lighting effects with this 24-key IR remote control and LED control unit, that's specifically designed to work with 12 VDC RGB LED light strips. Adjust brightness, color, fade in/out, and flash rate. Supports up to five meters of RGB LED light strips. Other tri-color, common anode LEDs may be used if configured to work with 12 VDC supply voltage. IR remote control uses a CR2025 battery (included).
Note: Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Specifications: • Power requirements: 12 VDC, 2A (minimum recommended), 12 VDC, 6A (with max current draw from each of three LEDs) • Power input: 2.1 x 5.5 mm, center positive • Output: Three CMOS drain-open output • Connection type: Common anode • Control unit dimensions: 63 mm (2.48") L x 35 mm (1.38") W x 22 mm (0.87") H.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)OffOn
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark orchid7 color flash
Static dark yellowStatic cyanStatic magentaAll fade out & fade in
Static yellowStatic light blueStatic pink7 color fade
Static light yellowStatic sky blueStatic purple3 color smooth transition
  • BrandSure Electronics
  • ModelLE-LL19111
  • Part Number073-002
  • UPC844632093357
  • Product CategoryAccent & Party Lighting
    (4 Reviews)
  • Weight0.15 lbs.
