Sure Electronics LE-LL14113 High Power LED Driver 10/20W
Brand:|Model: LE-LL14113|Part # 073-054
Power LEDs without using voltage dropping resistors with this 10/20W LED driver.
List Price$12.99
You Save39%
$7.91
Buy 4+$7.51
Part # 073-054
  • Drives up to 4 high power LEDs in series
  • Power LEDs without using voltage dropping resistors
  • Temperature and under/over voltage protection built-in
  • Uses MBI6651 step-down DC-DC converter IC
  • Optional pulse width modulation input for remote dimming
This 10/20W LED driver board uses a MBI6651 step-down DC-DC converter IC by Macroblock which features under voltage lock-out, over temperature protection, LED open-circuit protection, and LED short-circuit protection. This makes for a convenient, small package solution for driving chains of up to seven LEDs in series with a wide range of input voltages (9 to 35 VDC). Additionally, LEDs can be controlled using external pulse width modulation.
Specifications: • Input voltage: 9 to 35 VDC • Supply current (no load): 2 to 5 mA • Output voltage: 7.63 VDC • Output current: Up to 1491 mA • Over temperature protection: 175°C • Under voltage lockout trigger: 8.3 VDC • Dimensions: 1.80" L x 1.00" W x 1.23" H (45.8 x 25.5 x 31.4 mm).
Voltage required according to number of LEDs wired in series:
• 1 LED: 9 to 12 VDC • 2 LEDs: 18 to 24 VDC • 3 LEDs: 24 to 35 VDC • 4 LEDs: 30 to 35 VDC
Note: For more information regarding pulse width modulation control, please see the manual located in the Manuals/Resources section on the right. This LED driver is designed for high power LED.
  • BrandSure Electronics
  • ModelLE-LL14113
  • Part Number073-054
  • UPC844632093616
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.05 lbs.
View similar products to the Sure Electronics LE-LL14113 High Power LED Driver 10/20W
in the High-Power LED Assemblies product category.
