Sure Electronics LE-LL11114 High Power LED Driver 1W
Brand:|Model: LE-LL11114|Part # 073-048
Power LEDs without using voltage dropping resistors with this 1W LED driver.
List Price$8.99
You Save64%
$3.20
Buy 4+$3.04
Part # 073-048
  • Drives up to 6 LEDs in series
  • Power LEDs without using voltage dropping resistors
  • Temperature and under/over voltage protection built-in
  • Uses MBI6651 step-down DC-DC converter IC
  • Optional pulse width modulation input for remote dimming
This 1W LED driver board uses a MBI6651 step-down DC-DC converter IC by Macroblock which features under voltage lock-out, over temperature protection, LED open-circuit protection, and LED short-circuit protection. All of this makes for a convenient, small package solution for driving chains of up to seven LEDs in series with a wide range of input voltages (9 to 35 VDC). Additionally, LEDs can be controlled using external pulse width modulation.
Specifications: • Input voltage: 9 to 35 VDC • Supply current (no load): 2 to 5 mA • Output voltage: 3.07 to 17.55 VDC • Output current: Up to 339 mA • Over temperature protection: 175°C • Under voltage lockout trigger: 8.3 VDC • Dimensions: 1.80" L x 1" W x 0.68" H (45.7 x 25.4 x 17.2 mm).
Voltage required according to number of LEDs wired in series:
Red, yellow, or amber: • 1 LED: 9 to 12 VDC • 2 LEDs: 9 to 12 VDC • 3 LEDs: 12 to 24 VDC • 4 LEDs: 15 to 24 VDC • 5 LEDs: 19 to 35 VDC • 6 LEDs: 24 to 35 VDC
White, green, or blue: • 1 LED: 9 to 12 VDC • 2 LEDs: 9 to 12 VDC • 3 LEDs: 15 to 24 VDC • 4 LEDs: 19 to 24 VDC • 5 LEDs: 24 to 35 VDC • 6 LEDs: 27 to 35 VDC
Note: For more information regarding pulse width modulation control, please see the manual located in the Manuals/Resources section on the right.
  • BrandSure Electronics
  • ModelLE-LL11114
  • Part Number073-048
  • UPC844632093586
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.05 lbs.
View similar products to the Sure Electronics LE-LL11114 High Power LED Driver 1W
in the High-Power LED Assemblies product category.
Sure Electronics LE-LL11114 High Power LED Driver 1W is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from What is advertised, isn't what I receivedThe items advertised isn't what i received.Ordered four, two of them didn't work?These four had the connectors soldered to the PCB. Other orders that I placed before didn't have them soldered, which for me made it easier to install in the project boxes.Don't remember how many of them were different manufactures.Emailed the problem and they sent two new ones.
Date published: 2013-06-04
  • 2016-02-13T07:05CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-048, PRD, sort_mostRecent
