CLEARANCE
073-079_ALT_0
073-079_ALT_1
073-079_ALT_2
073-079_ALT_3
073-079_ALT_4
073-079_ALT_5
073-079_ALT_6
073-079_ALT_7
Sure Electronics Individual RGB SMD 3528 LEDs 5m Tape Lighting Strip with 24-Key Controller & Remote
Brand:|Model: DC-LE12123
Decorate your home, office, or car with 12V LED strip lighting. IP65 waterproof rated for indoor and outdoor use. 100 red, 100 green, and 100 blue LEDs are at your disposal. Use the whole 5 meter roll or cut the LED strip in 6" increments to a custom length. Includes 24-key controller.
List Price$49.99
Regular Price$29.98
You Save17%
Sale Price
$24.98
Part # 073-079
  • 100 red, 100 green, and 100 blue 3528 surface mount LEDs on a single strip
  • Includes 24-key control unit with wireless remote
  • Longer life and lower power consumption compared to rope lights
  • Flexible IP65 waterproof coating
  • Unlimited placement options with aggressive adhesive backing
These RGB LED tape strips are built with 9 bright, single-color 3528 surface mount LEDs (3 red, 3 green, and 3 blue) per every 6" for the great color density, 300 total. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each segment. Aggressive adhesive to affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 32 6" strip segments with nine LEDs per section (3 red, 3 green, and 3 blue). Each section features four solder points (voltage +, green, red, and blue) to create many different color combinations and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the included 24-key remote control LED control unit for color control or to create amazing effects. Each strip is pre-terminated with a 4" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant. IP65 waterproof-rated for outdoor use.
Note: Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • Overall dimensions (W x L x H): 0.44" x 196.80" x 0.125" (11 x 5000 x 3.2 mm) • Segment length: (32 segments per strip, 3 LEDs of each color per segment): 6".
LED Specifications: • LED type: SMD 3528 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens • Dimensions (L x W x H): 3.5 x 2.8 x 2.0 mm.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)OffOn
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark orchid7 color flash
Static dark yellowStatic cyanStatic magentaAll fade out & fade in
Static yellowStatic light blueStatic pink7 color fade
Static light yellowStatic sky blueStatic purple3 color smooth transition
  • BrandSure Electronics
  • ModelDC-LE12123
  • Part Number073-079
  • UPC848864000282
  • Product CategoryAccent & Party Lighting
    (2 Reviews)
  • Weight0.7 lbs.
View similar products to the Sure Electronics Individual RGB SMD 3528 LEDs 5m Tape Lighting Strip with 24-Key Controller & Remote
in the Accent & Party Lighting product category.
Sure Electronics Individual RGB SMD 3528 LEDs 5m Tape Lighting Strip with 24-Key Controller & Remote is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from Under cabinet lighting!I put these strips under the kitchen cabinets and they work great. I just leave them set on white all the time but I suppose I could use the remote for mood lighting. I cleaned the surfaces with rubbing alcohol first and I was careful to secure the ends so they couldn't start to peel.After a week, they're still stuck tight.
Date published: 2013-10-26
Rated 3 out of 5 by from LED strip, Part 2I first tried the DCLE12116 strip. It failed spectacularly after several weeks. Missing segments, missing colors... a total train wreck. (Should have returned it for refund... and may yet but the trail is pretty cold.) So I tried this version - separate R,G, and B LEDs. So far its decent, not perfect but decent. Over a 11' run, I have one segment (6") of red LEDs that are out. The strip is fairly well hard wired into the application and the missing reds are not noticeable most of the time or I'd return the spool and try again. That said, its a pretty cool way to add color lighting effects.
Date published: 2013-10-24
  • 2015-08-30T07:47CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_073-079, PRD, sort_mostRecent
Hi i just got my LEDS in the mail today and want to use them in my truck and i already know where im getting the power from but what plug do i need to power it because i cant find anything similar, PLEASE HELP
Asked by: BIGED28
In order to wire this to a battery or power source you can use a DC plug with a wire lead like the one below.http://www.parts-express.com/21mm-x-55mm-x-112mm-dc-plug-with-6-ft-cord--090-489
Date published: 2014-09-15
I love your led light strips! If I want to cut strips to lay side by side, what do I use to connect one end to the next? Thank you!
Asked by: Lynzi
These will have to be spliced with a 4 conductor wire soldered to each end. The gauge of the wire can be fairly small, 18-22 gauge is recommended.
Date published: 2014-01-06
does this strip light white? mine does not
Asked by: bigdeal
Yes these RGB strips will shine white although it is not as true as a solid white LED strip.
Date published: 2013-10-29
Power supply clarification needed
Sorry for the redundacy here, but a previous question answered by a PE staff member recommends 1 amp of power per 1 meter of light strip. Another person answered my question saying a 2 amp power supply is recommended for this 5 meter string. So my question is, will a 5 amp supply make the lights any brighter than a 2 amp supply for the same 5 meter string? I thought brightness with LEDs was a function of voltage, not amperage. Please clarify - if the brightness is the same, I'll buy a 2 amp supply.
Asked by: KBActive
This string will light up with 2 amps, but it will experience some "voltage sag"--especially when all the LEDs are "on". That's what happens with long speaker cables and amplifiers driving too low an impedance load. These are cool little lights--but feed them well and they will be happy.
Answered by: Joe from San Francisco
Date published: 2013-10-19
Power supply and effects
Two part question; 1) the pic shows a power supply, but from what I read, it is not included. Can a PE staff member please recommend an appropriate supply that you have in stock? 2) The controller shows "Flash, Strobe, Fade, and Smooth". Do all 4 effects on the controller function with these lights? Thanks in advance for answers.
Asked by: KBActive
The white box in the pic is not a power supply, that is the control box. The power supply I would recommend is below. Yes those functions will work with these lights.
Date published: 2013-10-18
Do you sell connectors for splicing together cut strips (other vendors have them) or should I just solder them?
Asked by: TIlardi
Well, these strips do have a M/F connector on them. Soldering them is one way to make a longer strip--but I always fold one under the next as a looped-together setup so you always have the option of a longer strip. In the field, it's always nice to have options.
Date published: 2013-10-11
  • 2015-08-29T09:14CST
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_073-079, PRD, sort_recentQuestionsFirst
