These RGB LED tape strips are built with 9 bright, single-color 3528 surface mount LEDs (3 red, 3 green, and 3 blue) per every 6" for the great color density, 300 total. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each segment. Aggressive adhesive is affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 32 6" strip segments with nine LEDs per section (3 red, 3 green, and 3 blue). Each section features four solder points (voltage +, green, red, and blue) to create many different color combinations and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the solder points and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Each strip is pre-terminated with a 4" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant. IP65 waterproof-rated for outdoor use.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • Overall dimensions (W x L x H): 0.44" x 196.80" x 0.125" (11 x 5000 x 3.2 mm) • Segment length: (32 segments per strip, 3 LEDs of each color per segment): 6".
LED Specifications: • LED type: SMD 3528 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens • Dimensions (L x W x H): 3.5 x 2.8 x 2.0 mm.
