Sure Electronics High Power RGBY LED Driver with Audio Sync
Brand:|Model: DE-DD13111
An audio synced light show is quick and simple with this RGB LED driver with audio sync. The four channel color organ will amaze audiences and friends alike.
List Price$24.99
You Save40%
$14.90
Buy 4+$14.16
Part # 073-056
  • Create an audio synced light show
  • 3.5 mm input and output for use with almost any audio device
  • Works with 4 x 1W quadcolor LED boards
  • Compact size offers many installation options
Creating an audio synchronized light show is made easy with this RGB LED driver with audio sync. As a four channel color organ, the audio input signal is filtered into one of four categories by frequency: low, medium, medium-high, and high. Each frequency category is then assigned a specific pulse width modulated output that feeds to the 4 x 1W quadcolor LED board for power and control. See below for frequency divisions and default color assignment. Requires 12 VDC power supply (sold separately). Eight pin interface cable included.
Specifications: • Power requirement: 12 VDC, 1A (2A recommended) • DC power jack: 2.1 mm ID, 5.5 mm OD • Audio input/output: 3.5 mm • Dimensions: 3" W W x 3" L x 0.74" H (76.2 x 76.2 x 18.7 mm).
Frequency Divisions:
• Low: 0-600 Hz • Medium: 600-3,000 Hz • Medium-high: 3,000-6,000 Hz • High: 6,000-20,000 Hz
Default Color Assignments:
• Low: White or yellow • Medium: Blue • Medium-high: Green • High: Red
  • BrandSure Electronics
  • ModelDE-DD13111
  • Part Number073-056
  • UPC844632093623
  • Product CategoryHigh-Power LED Assemblies
    (3 Reviews)
  • Weight0.25 lbs.
View similar products to the Sure Electronics High Power RGBY LED Driver with Audio Sync
in the High-Power LED Assemblies product category.
Sure Electronics High Power RGBY LED Driver with Audio Sync is rated 2.3333 out of 5 by 3.
Rated 3 out of 5 by from needs more supportso let be clear is not an audio controlled color organ. the colors don't really change they add or subtract basted on the volume of the input. they say you can program this but i have not got that far better off buying an Arduino and using the PWW out on the board for the lights
Date published: 2014-12-06
Rated 3 out of 5 by from Could be BetterI purchased this a few weeks ago and just did set it up. The LED is very bright and lights a room well. What I do not like is you cannot control the brilliance of the RGBW, the Blue and White LEDs over powers the Red and Green to the point they are not seen.
Date published: 2014-12-03
Rated 1 out of 5 by from Concept good but poor execution.Thinking this would do a good job of lighting a rotating fiber optics globe. Did a test to check operation with the matching 4 color led driver. The green light immediately comes on full and stays on. The other leds blinked and went off. Applying stereo a sound source made the three leds flash as expected with intensity and frequency separation. The green led just stays on full brilliance. These are very bright 1 watt lights.No way to adjust the gain without the USB interface board. The leds do get hot. Not user friendly at all. No instructions with either unit. Had to DL the PDF files from Sure site. The links are broken on Parts-Express site. Not worth sending back for a refund because of the shipping costs. Out $33.00, I will not buy another Sure Electronics product.
Date published: 2012-02-18
  • 2015-08-28T22:11CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_073-056, PRD, sort_mostRecent
So when people have music and light on their house do a show this music sync? is this power full enough to create that?
Asked by: esteban bor
No. This unit is designed to work with an LED Quadcolor Board.
Answered by: TomI
Date published: 2015-03-02
is the RGBY led drived controlled by frequency change and amplitude ?
Asked by: Gigs
is the RGBY led driver controlled by frequency change and amplitude change ?
Answered by: Gigs
Date published: 2015-01-20
Is there anything like this for just RGB lights? I don't have RGBY lights.
Asked by: Mnamee
Unfortunately we do not have anything at this time.
Date published: 2014-02-06
Is there a schematic included in the instructions?
I too would like to use this module to power my own LED strings. Your suggestion to buy the LED module and then tap off to use other LED's seems reasonable, but a pinout/schematic would also help in customization.
Asked by: robfed4
There is a lot of information with the .pdf instructions, including the schematics and wiring diagrams for each module. I believe that these units are more flexible than in the basic description.
Answered by: robfed4
Date published: 2012-01-27
I have the LED strips...would this work with the strips? or do they make anything that would be able to work without making from scratch?
Asked by: Evin
This board is intended for decoding sound into light controlling sequences. To do anything, you need to get the RGBY emitter board, or just the kit with both, and you will be able to run the RBG strips with a jack off of the emitter board itself. I am not sure if there is any other way. I hope that this helps!!!
Answered by: BigRich92
Date published: 2011-12-03
all i need is a 12v power supply?/
Asked by: BOC777
to power this all you need is a 12v power supply, but you will also need an led board sold here and an audio input too.
Date published: 2011-10-21
  • 2015-08-28T21:27CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_073-056, PRD, sort_recentQuestionsFirst
