Sure Electronics High Power RGB LED Control Unit with 24-Key IR Remote
Brand:|Model: LE-LL19113
This high power RGB LED control unit, with IR controller, offers nearly unlimited potential for the use of RGB LED strip lighting (or up to 3 different single-color LED strips). You can also sync multiple control units together for increased area coverage. Includes 24-key IR remote control.
List Price$59.99
You Save45%
$32.95
Buy 10+$28.25
Part # 073-005
  • Control up to 49 feet of LED strip lighting (RGB or 3 different colors)
  • Link multiple controllers together—up to 164 feet apart!
  • Includes 24-key IR remote control
  • Adhesive backed and includes screws for permanent mounting
  • Requires power supply
This high power RGB LED control unit allows you to power and control up to 49 feet (15 meters) of RGB LED strips on a single run. Additionally, multiple controllers can be daisy-chained and synced together using the built-in data bus, for single control over multiple LED strips. The maximum length of the data bus is 164 feet (50 meters), and provides an amazing amount of area coverage. Each controller requires its own power supply.
A 24-key infrared remote control is included for quickly powering LED strips on or off, changing through one of 16 different colors, controlling brightness, or for using one of the four built in color loop modes: flash (a 7-color flashing loop), strobe (3-color strobe loop), fade (7-color quick fade), or smooth (7-color smooth fade).
Also, this controller features a function control button for local function changes, and is designed to work with both 12 VDC and 24 VDC LED strips (do not mix strip voltages), and can alternatively power up to three different single-color strips on a single controller. Adhesive has been pre-mounted on the back of the controller for permanent placement, and two mounting screws are included. IR remote control uses a single CR2025 battery (battery included), see Related Items for replacements.
Note: Only use the correct power supply for the stated LED strip voltage. Please refer to the LED strip packaging or manufacturer prior to connecting power supply to controller. Never link the LED outputs of multiple controllers together. Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings. For consistent color brightness wire each strip in parallel directly to the controller.
• Input power (maximum): 12 VDC, 15A or 24 VDC, 15A
• Output power (maximum): 180W (12 VDC), 360W (24 VDC)
• Output power per color (maximum): 60W (12 VDC), 120W (24 VDC)
• Control unit dimensions: 4.76" L x 2" W x 1.02" H
• IR remote control range: 23 ft. (7 meters)
  • BrandSure Electronics
  • ModelLE-LL19113
  • Part Number073-005
  • UPC848864000251
  • Product CategoryAccent & Party Lighting
    (3 Reviews)
  • Weight0.55 lbs.
Sure Electronics High Power RGB LED Control Unit with 24-Key IR Remote is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Works GreatI purchased this controller with a high power transformer to run a 60 foot continuous strip. The controller was easy to set up and works well. The only thing I have noticed which I think is because my led strip is so long; is that the white leds start to fade to a yellowish color towards the end of the strip. All of the other colors work great, and the controller is easy to use.
Date published: 2014-05-07
Rated 5 out of 5 by from Rgb led controller!The controller is prefect. Easy to install the most reliable led controller I ever used. Love this controller and it doesn't feel or look cheap. I would recommend to anyone.
Date published: 2013-08-11
Rated 5 out of 5 by from Just what we neededIt does what it says, provides synced control to multiple LED strips. We installed frosted glass shelving in our basement bar and connected five separate LED strips for a total of roughly 45', three glass shelves and two storage shelves. All run with one 12V 30 amp power supply connected to this controller. Works great, everything in sync whether its fading, strobing, or a static color. Will buy another for LED strips in up lighting our home theatre.
Date published: 2013-07-26
  • 2015-08-04T08:36CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_073-005, PRD, sort_mostRecent
I'm putting LED light strips in my car to light the floor in four separate locations. What power source would I need to connect this to and where can I get it?
Asked by: ModJunkie
As long as you are using standard 12VDC strips you don't need any specific power source, just power from the battery in the vehicle. You can either install a switch, or wire it to an ignition source that is only powered when the car is on.
Date published: 2015-01-23
Is this unit the same as Velleman CHLSC1 (073-220) ?
Asked by: Ninja
Different manufacturer and warranty.
Answered by: TomI
Date published: 2015-01-20
Is this CL2 rated (since the individual outputs are 5A each)? I need to run the wiring from the controller via in-wall CL2 rated wire.
Asked by: DaveP137
The IR controller itself is not cl2 rated but you can use CL2 wiring to connect it through the wall.
Answered by: TomI
How does it link different controllers together?
Asked by: Schneider
Any two-conductor wire connected between the data terminals will work. A light gauge speaker wire works just fine.
Answered by: Eric Chandler
Date published: 2014-09-24
12v 25A 300Watt power supply for this unit?
I intend to connect two of these controllers (linked) to five 15' LED RGB strips. By my calculations that will be a total of 25A (5 at 5A each).The installation will be a protected outdoor location - not likely to get wet but better to have a sealed power supply to protect against bugs.Can you recommend one power supply to supply all (110v to 12v at 25 Amps/300 Watts) or two (110v to 12v at 15 A / 180 Watts), again better sealed than with vents.
Asked by: Scooter1
The power supplies listed below will do the job if you have enough A/C line power. [volts-watts].
Answered by: Joe from San Francisco
Date published: 2014-11-27
Does this High Power RGB Control Unit have a memory?
Units will be controlled by a wall switch (remote installation). When the power is reapplied (switch is flipped on) will the controllers return to the last setting (color and brightness)?Also, this unit appears to be identical to the Velleman CHLSC1. Is that correct?
Asked by: Scooter1
Yes these do return to the setting they were last on after being powered off. This item has exactly the same functionality as the Velleman product we offer.
Date published: 2013-12-03
  • 2015-08-04T08:44CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_073-005, PRD, sort_recentQuestionsFirst
