Sure Electronics High Power LED Driver 10/20W
Brand:|Model: LE-LL14113
Power LEDs without using voltage dropping resistors with this 10/20W LED driver.
List Price$12.99
You Save39%
$7.91
Buy 4+$7.51
Part # 073-054
  • Drives up to 4 high power LEDs in series
  • Power LEDs without using voltage dropping resistors
  • Temperature and under/over voltage protection built-in
  • Uses MBI6651 step-down DC-DC converter IC
  • Optional pulse width modulation input for remote dimming
This 10/20W LED driver board uses a MBI6651 step-down DC-DC converter IC by Macroblock which features under voltage lock-out, over temperature protection, LED open-circuit protection, and LED short-circuit protection. This makes for a convenient, small package solution for driving chains of up to seven LEDs in series with a wide range of input voltages (9 to 35 VDC). Additionally, LEDs can be controlled using external pulse width modulation.
Specifications: • Input voltage: 9 to 35 VDC • Supply current (no load): 2 to 5 mA • Output voltage: 7.63 VDC • Output current: Up to 1491 mA • Over temperature protection: 175°C • Under voltage lockout trigger: 8.3 VDC • Dimensions: 1.80" L x 1.00" W x 1.23" H (45.8 x 25.5 x 31.4 mm).
Voltage required according to number of LEDs wired in series:
• 1 LED: 9 to 12 VDC • 2 LEDs: 18 to 24 VDC • 3 LEDs: 24 to 35 VDC • 4 LEDs: 30 to 35 VDC
Note: For more information regarding pulse width modulation control, please see the manual located in the Manuals/Resources section on the right. This LED driver is designed for high power LED.
  • BrandSure Electronics
  • ModelLE-LL14113
  • Part Number073-054
  • UPC844632093616
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.05 lbs.
View similar products to the Sure Electronics High Power LED Driver 10/20W
in the High-Power LED Assemblies product category.
Sure Electronics High Power LED Driver 10/20W is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from 10W LED and 10/20W LED power driverThe above items are beyond one's experience and result.Even though the rated power is 10W, the LED had brighness of 100W Mercury vapour lamp, but fraction of it's energy consumption.I will buy 5W LEDs (6) for perimeter lighting, 10W is like flood light and may not be suitable.Thank you Parts Express people.SincerelyKumar
Date published: 2011-11-10
  • 2015-07-30T07:32CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-054, PRD, sort_mostRecent
Is a driver required for each LED or can this drive a series of them?  I'm interested in building my own exterior lighting using LED's vs the typical 12v/11w bulbs.  Thank  you
Asked by: JoeSab
The product can drive chains of up to seven LEDs in series.   Answered my own question.
Answered by: JoeSab
Date published: 2014-12-29
Does this require a regulated power supply?
Asked by: MMBB
No it just requires the voltage to stay above : 8.3 VDC and not exceed 35 VDC, the voltage can waver anywhere within that range. With most voltage sources as the amperage increases the source voltage decreases due to the added load and most transformers indicate the maximum amerpage that can be requested from the source in order for it to maintain the stated voltage output.That is why it states: Supply current (no load): 2 to 5 mA
Answered by: Wkmiller
  • 2015-07-30T08:48CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_073-054, PRD, sort_recentQuestionsFirst
