Sure Electronics DC-LE14133 High Power White LED 20W with Heatsink and Driver
Brand:|Model: DC-LE14133|Part # 073-038
When a lot of light is needed, count on high power white LEDs.
List Price$49.99
You Save54%
$23.00
Buy 4-9 $21.75
Buy 10+$19.50
Part # 073-038
  • Great for DIY spotlights
  • Combine with fiber optics for amazing lighting effects
  • Low power requirement
  • Ultra-wide 120° viewing angle with 1600 lumens of output
Create high power lights with the High Power series of LEDs. This LED assembly features 1600 lumens of output and a 120° viewing angle. A low power requirement allows you to build an array that sips current, for hours of use. Heatsink and regulated voltage driver are included and required for operation. Four easy attachment holes have been pre-drilled for simple heatsink mounting. RoHS compliant.
LED driver specifications: • Input voltage: 9 to 35 VDC • Supply current (no load): 2 to 5 mA • Output voltage: Same as input voltage • Output current: Up to 1491 mA • Over temperature protection: 175°C • Under voltage lockout trigger: 8.3 VDC • Dimensions: 1.80" L x 1.00" W x 1.23" H (45.8 x 25.5 x 31.4 mm).
LED specifications: • Size: 2.22" L x 2.05" W x 0.17" H (56.5 x 52 x 13 mm) • Lens color: Water clear • Forward current: 1.4A • Requires a forward voltage of 24 to 30 VDC • Viewing angle: 140° • Luminous intensity: 1600 lumens (500,000 mcd @ 120°) • Lifetime: 100,000 hours.
Note: The positive terminal is the rail with one hole. Please check continuity from the positive solder pad (on the LED) to the rail for proper polarity prior to power connection. Do not stare directly into LED when in use. Do not apply power to this LED without a proper heatsink in place.
  • BrandSure Electronics
  • ModelDC-LE14133
  • Part Number073-038
  • UPC844632093531
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.4 lbs.
View similar products to the Sure Electronics DC-LE14133 High Power White LED 20W with Heatsink and Driver
in the High-Power LED Assemblies product category.
