CLEARANCE
Sure DC-LE14116 High Power White LED 5W
Sure Electronics DC-LE14116 High Power White LED 5W
Brand:|Model: DC-LE14116|Part # 073-030
When a lot of light is needed, count on high power white LEDs.
List Price$9.99
You Save40%
$5.96
Buy 4+$5.66
Part # 073-030
  • Great for DIY security lights
  • Low power requirement
  • Ultra-wide 160° viewing angle with 280 lumens of output
Create high power lights with the High Power series of LEDs. This LED features 280 lumens of output and a 140° viewing angle. A low power requirement allows you to build an array that sips current, for hours of use.
Specifications: • Size: 0.79" dia. x 0.31"  H (20 x 8 mm)• Lens color: Water clear • Forward current: 700 mA • Forward voltage: 7.0 to 7.5 VDC • Viewing angle: 140° • Luminous intensity: 280 lumens (67000 mcd @ 140°).
Note: This LED is designed for use with an LED driver and heatsink. Please see the Related Items section on our website. Do not stare directly into LED when in use. Do not apply power to this LED without a proper heatsink in place.
  • BrandParts Express
  • ModelDC-LE14116
  • Part Number073-030
  • UPC844632093494
  • Product CategoryHigh-Power LED Assemblies
    (1 Reviews)
  • Weight0.05 lbs.
View similar products to the Sure Electronics DC-LE14116 High Power White LED 5W
in the High-Power LED Assemblies product category.
Sure Electronics DC-LE14116 High Power White LED 5W is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from BrightI bought a 3 pack of 1 watt flashlights( Techlite Lumin Master) for a big box store and am very happy with the price/performance of them. But as tinkerers do, i opened one up to find the same base as the 5 watt here. Two solder joints later, a slight adjustment to the plastic cover holding the LED in place and an easy mod to change three AAA's to two CR 123 lithium ion rechargeable batteries, I have the best 5 watt flashlight you can buy for 11 dollars.Admittedly I do not know how long the whole thing will last, as the driver in the flashlight is made for 4.5 volts. The heatsink is the whole flashlight. But I can remove the driver if it fails because two CR 123 combine to 7.4 volts and 1000 mAh's which is in the operational realm of the LED. So far about 4 hours of testing without a driver and it still works. I expect the lack of the PE driver will probably cause some life expectancy to diminish, but for now even if I had to replace the LED every so often, I'm OK with that. Its bright, really bright and small.
Date published: 2012-01-20
  • 2016-02-11T06:59CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-030, PRD, sort_mostRecent
