073-079_ALT_0
073-079_ALT_1
073-079_ALT_2
073-079_ALT_3
073-079_ALT_4
073-079_ALT_5
073-079_ALT_6
073-079_ALT_7
Sure Electronics DC-LE12123 Individual RGB SMD 3528 LEDs 5m Tape Lighting Strip with 24-Key Controller & Remote
Brand:|Model: DC-LE12123|Part # 073-079
Decorate your home, office, or car with 12V LED strip lighting. IP65 waterproof rated for indoor and outdoor use. 100 red, 100 green, and 100 blue LEDs are at your disposal. Use the whole 5 meter roll or cut the LED strip in 6" increments to a custom length. Includes 24-key controller.
  • 100 red, 100 green, and 100 blue 3528 surface mount LEDs on a single strip
  • Includes 24-key control unit with wireless remote
  • Longer life and lower power consumption compared to rope lights
  • Flexible IP65 waterproof coating
  • Unlimited placement options with aggressive adhesive backing
These RGB LED tape strips are built with 9 bright, single-color 3528 surface mount LEDs (3 red, 3 green, and 3 blue) per every 6" for the great color density, 300 total. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each segment. Aggressive adhesive to affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 32 6" strip segments with nine LEDs per section (3 red, 3 green, and 3 blue). Each section features four solder points (voltage +, green, red, and blue) to create many different color combinations and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the included 24-key remote control LED control unit for color control or to create amazing effects. Each strip is pre-terminated with a 4" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant. IP65 waterproof-rated for outdoor use.
Note: Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • Overall dimensions (W x L x H): 0.44" x 196.80" x 0.125" (11 x 5000 x 3.2 mm) • Segment length: (32 segments per strip, 3 LEDs of each color per segment): 6".
LED Specifications: • LED type: SMD 3528 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens • Dimensions (L x W x H): 3.5 x 2.8 x 2.0 mm.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)OffOn
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark orchid7 color flash
Static dark yellowStatic cyanStatic magentaAll fade out & fade in
Static yellowStatic light blueStatic pink7 color fade
Static light yellowStatic sky blueStatic purple3 color smooth transition
  • BrandSure Electronics
  • ModelDC-LE12123
  • Part Number073-079
  • UPC848864000282
  • Product CategoryAccent & Party Lighting
    (2 Reviews)
  • Weight0.7 lbs.
View similar products to the Sure Electronics DC-LE12123 Individual RGB SMD 3528 LEDs 5m Tape Lighting Strip with 24-Key Controller & Remote
in the Accent & Party Lighting product category.
