CLEARANCE
073-069_ALT_0
073-069_ALT_1
Sure Electronics DC-LE12121 White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC
Brand:|Model: DC-LE12121|Part # 073-069
Add cool white lighting almost anywhere with this 12 VDC, 60 white SMD 3528 LED tape strip. The flexible, durable design can be attached to many different surfaces using the aggressive adhesive affixed to the back of the strip for permanent mounting. 6000 to 6500K color temperature.
List Price$19.99
You Save50%
$9.98
Buy 4+$9.78
Part # 073-069
  • Perfect for illumination in home or in your car
  • Low 12 VDC power requirement
  • Aggressive backing for permanent placement and edge lighting
  • Wide 150° viewing angle, 6000 to 6500K color temperature
  • Combine with an LED controller for brightness control and lighting effects (sold separately)
This LED tape strip is built with 60 bright white surface mount 3528 LEDs per each half meter strip (19.69") for maximum brightness. LED strips are great for use as indoor strip lighting or illuminating a display case. The flexible, durable design hugs corners and can be attached to many different surfaces using the aggressive adhesive affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 20 miniature 1" strip segments with three LEDs per section. Each section features two solder points (voltage + and ground -) for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in: Simply connect a 12 VDC power supply (up to a 12 VDC, 3A power supply is recommended and sold separately) to the wire leads and go! Additionally, you can use either the 24 or 44-key remote control LED control unit to adjust brightness or add flashing effects (sold separately). CE and RoHS compliant.
Note: This LED strip is designed for interior use only. To use with an LED controller, connect the red lead to the black wire of the 24-key or 44-key LED control unit and the black to any of the other colors. Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth.
Strip Specifications:
• Power requirements (per strip): 12 VDC, 2A
• Overall dimensions (W x L x H): 0.39" x 19.68" x 0.10" (10 x 500 x 2.5 mm)
• Segment dimensions (20 segments per strip): 1" (25.4 mm) L
• Power pigtail length: 3.8"
LED Specifications:
• LED type: SMD 3528
• Viewing angle: 150°
• Color temperature: 6000 to 6500K
• Dimensions (L x W x H): 3.5 x 2.8 x 2 mm
  • BrandSure Electronics
  • ModelDC-LE12121
  • Part Number073-069
  • UPC844632098406
  • Product CategoryAccent & Party Lighting
    (6 Reviews)
  • Weight0.025 lbs.
View similar products to the Sure Electronics DC-LE12121 White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC
in the Accent & Party Lighting product category.
