073-072_ALT_0
073-072_ALT_1
073-072_ALT_2
073-072_ALT_3
073-072_ALT_4
073-072_ALT_5
073-072_ALT_6
073-072_ALT_7
073-072_ALT_8
073-072_ALT_9
Sure Electronics DC-LE12117 RGB 30 LED 1m Tape Lighting Strip 12 VDC Waterproof IP65
Brand:|Model: DC-LE12117|Part # 073-072
Create your own custom lighting with RGB LED tape strips. Pre-applied adhesive attaches to almost any surface and the sealed design is impact resistant and weatherproof. This 39.36" long strip features 30 RGB LEDs and can be cut to custom lengths.
List Price$29.99
You Save47%
$15.90
Buy 4+$15.11
Part # 073-072
  • 30 LEDs with seven different color combinations
  • Longer life and lower power consumption compared to rope lights
  • Connects to LED remote control units for custom effects
  • Cut lines on circuit board for creating miniature segments
  • Impact resistant and weatherproof for outdoor use with adhesive backing
These LED tape strips are built with 3 bright surface mount RGB LEDs per every 3.94" for amazing color density. These strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each strip. Aggressive adhesive is affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 10 miniature 3.94" strips with three RGB LEDs per section. Each section features four solder points (voltage +, green, red, and blue) to create one of seven different colors and for easy daisy-chaining.
To facilitate ease of use, Sure Electronics has built-in voltage dropping resistors. Simply connect a 12 VDC power supply (up to a 12 VDC, 3A power supply is recommended and sold separately) to the solder points (see wiring diagram in Manuals/Resources section on the right) and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Pre-terminated with a 5" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant and IP65 rated  (no ingress of dust; complete protection against contact. Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects.).
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 1.2A • Overall dimensions: 0.44" W x 39.36" L x 0.125" H (11 x 1000 x 3.2 mm) • Segment dimensions (10 segments per strip): 3.94" L (100 mm) L.
RGB LED Specifications: • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
  • BrandSure Electronics
  • ModelDC-LE12117
  • Part Number073-072
  • UPC844632093708
  • Product CategoryAccent & Party Lighting
    (2 Reviews)
  • Weight0.2 lbs.
View similar products to the Sure Electronics DC-LE12117 RGB 30 LED 1m Tape Lighting Strip 12 VDC Waterproof IP65
in the Accent & Party Lighting product category.
Videos
