Sure Electronics Common Cathode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13137|Part # 073-112
This package includes 10 common cathode RGB LEDs together with voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
List Price$7.99
You Save38%
$4.98
Buy 4+$4.70
Part # 073-112
  • Rated to last over 10 years
  • Includes voltage dropping resistors for 5 VDC and 12 VDC source voltage
  • Up to 5,000 mcd of output
RGB LEDs are great for creating custom light effects for displays, in vehicles, on motorcycles, instrument panels... anywhere accent lighting is needed. These RGB LEDs are waterproof for use on boats or outdoors and are tested to last 100,000 hours (over 10 years) and use virtually no power at all—1/4 watt at most—while providing up to 5,000 mcd of output. Also included are resistors to use these common cathode RGB LEDs with 5 or 12 VDC sources.
Use the larger included resistors in series with the 12 VDC power supply positive and the desired color's anode. Use the smaller resistor in series with the 5 VDC power supply positive and the desired color's anode.
• Size: 5 mm
• Lens color: water clear
• Forward current: 20 mA
• Life rating: 100,000 hours
• Forward voltage: Red: 2 to 2.4 VDC, Green: 3.4 to 3.8 VDC, Blue: 3.4 to 3.8 VDC
• Viewing angle: 25° to 35°
• Luminous intensity: 4,000 to 5,000 mcd
  • Size5mm (T-1 3/4)
  • Emitting ColorRGB
  • Lens Type / ColorWater Clear
  • Luminous Intensity4000-5000 mcd
  • Application TypeTri-color
  • BrandSure Electronics
  • ModelDC-LE13137
  • Part Number073-112
  • UPC848864000305
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.01 lbs.
View similar products to the Sure Electronics Common Cathode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
