Sure Electronics Blue LED Temperature Display Internal Sensor
Brand:|Model: ME-TM12123|Part # 320-504
Quickly check the temperature of your car or amplifier rack with this LED temperature display.
Part # 320-504
  • Measure a local environment in °C or °F with on-board sensor
  • Auto-sensing brightness and auto temperature conversion
  • Perfect for the precise temperature monitoring on a car or truck''s dash
  • Wide-range working voltage
Temperature displays offer the ability of measuring a local environment in either Celsius (°C) or Fahrenheit (°F), making it perfect for monitoring the temperature in your equipment closet.
Three 7-segment bright blue LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings and offers the ability to change the display from Celsius to Fahrenheit with a wave of a hand. The small housing footprint opens up application possibilities and since it can run on 12 VDC (8.5 to 26 VDC working voltage), this display is right at home in your car or truck. Power cable included.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: 0°C (32°F) to 60°C (140°F) • Display resolution: 0.1° (@ -9.9°C/°F to 99.9°C/F), 1° (@ 100°F and above) • Accuracy: ± 2.0°C • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
  • BrandParts Express
  • ModelME-TM12123
  • Part Number320-504
  • UPC844632093173
  • Product CategoryPanel Meters
    (1 Reviews)
  • Weight0.25 lbs.
