Sure Electronics Blue LED 7-30 VDC Panel Meter
Brand:|Model: ME-DV42331
This panel meter is the perfect tool for monitoring DC voltage.
List Price$14.99
You Save21%
Buy 4+$11.25
Part # 320-508
  • Monitor stored batteries
  • Works off battery voltage
  • Low power consumption
  • Auto-brightness conserves power consumption
Measure DC voltages from 7 to 30 VDC quickly and accurately with this panel meter. Perfect for monitoring stored vehicle or tool batteries, three 7-segment bright blue LEDs indicate voltage without requiring a separate power supply. 8" probe cable included.
Specifications: • Power requirements: 7 to 30 VDC • Power consumption: 36 mA (@ 12 VDC) • Display type: 3-2/3 digits • Range: 7 to 30 VDC • Accuracy: ± 0.15 VDC • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
  • BrandSure Electronics
  • ModelME-DV42331
  • Part Number320-508
  • UPC844632093197
  • Product CategoryPanel Meters
    (6 Reviews)
  • Weight0.25 lbs.
View similar products to the Sure Electronics Blue LED 7-30 VDC Panel Meter
in the Panel Meters product category.
Sure Electronics Blue LED 7-30 VDC Panel Meter is rated 4.8333 out of 5 by 6.
Rated 5 out of 5 by from Blue LED panel meterI'm using this in a camcorder remote control portable case and needed a simple way to monitor my battery voltage (i.e. two wires and no separate meter supply voltage) this IS the solution. While this dimension fit my console 'space budget' a smaller dimension would be welcom.
Date published: 2014-05-27
Rated 5 out of 5 by from Awesome MetersI bought 2 of these so I can monitor my amplifiers voltage and they're doing just as I was told they would do!
Date published: 2014-03-01
Rated 5 out of 5 by from perfect monitorThis filled my requirement perfectly. I am using this meter to monitor a marine battery that powers a back-up sump pump in our basement. Its high visibility permits it to be seen from far away. You could not achieve this with an analog meter. I am pleased with this purchase. I must also add that Parts-Exp. shipping is very fast. I am duly impressed.
Date published: 2012-02-17
Rated 5 out of 5 by from great for powered ipod boxive used them in about ten or more projects, and have no compaints. basic,simple, easy, perfect. buy them
Date published: 2012-01-31
Rated 5 out of 5 by from volt meterThese volt meters work great!!! I use these mounted in asmall plastic cabinet and would look great in a nice finished wood cabinet. I'm using this meter to monitor12 volt power supply that I have connected to my amatuer radio equipment. They work really well!!!Terry/KC9ITS
Date published: 2012-01-15
Rated 4 out of 5 by from Good unit for the price, but a bit bigThis unit offers exactly as described, flawlessly, but the unit display could be a bit smaller. I guess it depends on what you are using it for, but this unit is not designed with limited space in mind. Cheers!
Date published: 2011-11-02
  • 2015-10-09T06:47CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_320-508, PRD, sort_mostRecent
please email  for a prompt reply.
Wire this in parallel?
I have a car stereo wired to a 24v car battery.Can I simply wire this in parallel with the car stereo to measure the voltage of my Battery?
Asked by: Jebus
Yes, wire it in parallel like you would any voltage meter. Red goes to +, black to - , so no surprise there.Here is the manual in case you want to know more:
Answered by: notlance
Date published: 2012-01-21
  • 2015-10-09T07:44CST
  • loc_en_US, sid_320-508, PRD, sort_recentQuestionsFirst
Get Sales Flyer
