Sure Electronics Blue LED 10V Programmable Multifunction Panel Meter
Brand:|Model: ME-DV32423|Part # 320-516
Create your own measurement system with this programmable panel meter.
Part # 320-516
  • Designed to work with variable voltage producing sensors
  • Completely customizable, displays both numbers and letters
  • Includes USB to RS232 adapter and USB cable
  • Auto-brightness and reverse polarity protection built-in
  • Great for automotive and industrial applications
This unique multifunction panel meter is programmable to give you the ability to define the way your measurement output is displayed and scaled when used with variable DC voltage sensing equipment such as those measuring weight, temperature, humidity, velocity, pressure, or current. Also this panel meter doubles as a versatile 0-10 VDC voltage meter.
Four bright blue 7-segment LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings. Custom startup greetings are made possible with the custom software (please see Manuals/Resources for instructions and Software section below for drivers and computer software). Includes panel meter, connection cables, and USB to RS232 adapter, and USB cable.
Specifications: • Power requirements: 8.5 to 30 VDC • Power consumption: 30 mA (@ 12 VDC) • Signal input range: 0 to 10 VDC • Respond rate: 1 second • Accuracy: 0.5% • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
Required Software (Windows XP compatible, with newer Microsoft operating systems it is recommended to open these files in XP compatibility mode):
• Drivers
Software
  • BrandParts Express
  • ModelME-DV32423
  • Part Number320-516
  • UPC844632093234
  • Product CategoryPanel Meters
    (1 Reviews)
  • Weight0.3 lbs.
