Sure Electronics Battery Powered Bluetooth Wireless Audio Receiver with Power Supply White
Brand:|Model: MB-CM15112|Part # 320-354
Add Bluetooth support to nearly any amplifier, receiver, or car stereo with an audio input using this battery powered Bluetooth receiver. Streams up to 10 meters, compliant with Bluetooth 2.0, and supports A2DP v1.2. Stereo 3.5 mm male-to-male patch cable required.
List Price$29.99
You Save34%
ShippingGROUND ONLY
$19.90
Buy 4+$18.48
Part # 320-354
  • Portable battery powered Bluetooth receiver
  • Works with Android smartphones, tablets computers, iPhones, and iPads
  • Stream audio wirelessly from devices up to 33 feet away
  • Bluetooth 2.0 compliant and supports A2DP v1.2
  • Includes power supply and 29.5" USB A Male to USB B mini Male charging cable
Cut the cord on your smartphone, iPod, iPhone, iPad, tablet computer, or laptop and enjoy streaming audio wirelessly (up to 32.8 feet) to your stereo receiver using this battery powered Bluetooth receiver (hands-free phone operation not supported). You can even add Bluetooth functionality to car stereos with a 3.5 mm (1/8") auxiliary input. Also works as a fixed-gain wireless headphone amplifier.
The small receiver fits in the palm of your hand—great for users on the go—and complies with Bluetooth 2.0, as well as A2DP v1.2. A 3.7V, 250 mAh lithium polymer (Lipo) battery is built-in and allows you to stream Bluetooth audio for hours, even when there isn't a readily available power source. A mini USB port is built onto the housing for charging the battery over a computer's USB port or the included 5V 500 mA power supply and included 29.5" USB A male to mini USB B male charging cable.
Pairing is quick and simple: turn on your connecting device's Bluetooth function, set your device to discoverable, turn the Bluetooth receiver on (initially indicated by alternating red and blue flashing LEDs), locate the SF-LY001 on your device and select it, finally enter a PIN of 0000.
The alternating red and blue LEDs will change to a flashing blue LED once connected, and you are ready to start streaming audio. Stereo 3.5 mm male-to-male patch cable or stereo 3.5 mm male to stereo RCA adapter cable required for operation (please see Related Items section on the right for recommendations).
Also available in black
This battery powered Bluetooth receiver is fairly sensitive to audio inputs. If you experience distortion, it is likely caused by overdriving the wireless audio input from the source device (such as a smartphone). If you experience distortion, turn the volume down on the source device from maximum to half volume level. The maximum volume level without distortion will vary by source device.
• Internal battery: 3.7 VDC, 250 mAh lithium polymer
• Output connector: Stereo 3.5 mm (1/8") jack
• Complies with Bluetooth 2.0 standard
• Supports A2DP v1.2
• Maximum distance: 10 meters (32.8 feet) line-of-sight
• Included power supply specifications: 5 VDC, 500 mA
• 29.5" USB A Male to USB B Mini Male cable included
Note:The USB connection on this device is for the charging of the internal battery only. Audio is sent out via the 3.5 mm jack only. The USB cable included is not meant for use as a data cable.
Ground loops can occur (hum or buzzing sound) when used with a grounded (3-prong plug) power source. Please see the Related Items section for the Axxess 3.5 mm ground loop isolator to solve this issue if it occurs.
This device does not support phone call features, it is a receiver only.
  • BrandSure Electronics
  • ModelMB-CM15112
  • Part Number320-354
  • UPC6932564225558
  • Product CategoryBluetooth Receivers & Transmitters
    (26 Reviews)
  • Weight0.25 lbs.
View similar products to the Sure Electronics Battery Powered Bluetooth Wireless Audio Receiver with Power Supply White
in the Bluetooth Receivers & Transmitters product category.
Videos
