320-3370_ALT_0
320-3370_ALT_1
320-3370_ALT_2
Sure Electronics AA-AA11136 Two Conductor Screw Terminals for Amplifier Boards 10 Pcs.
Brand:|Model: AA-AA11136|Part # 320-3370
Add wire installation ease on amplifier boards with these screw-down two-conductor terminals. A high 300 VAC, 10A power rating allows these to be used for power and speaker wire connections. Accepts 12 to 22 AWG wire.
List Price$7.99
You Save40%
$4.83
Buy 4+$4.10
Part # 320-3370
  • Rated to handle 300 VAC at 10 amps
  • Easy to mount and solder
  • Accepts 12 to 22 AWG wire
This set of ten two-conductor screw-down terminals were designed with amplifier boards in mind. Rated up to 300 VAC at 10 amps, these are perfect for use as power and ground input terminals as well as speaker output terminals and accept 12 to 22 AWG wire. The side stackable design allows you to build a continuous strip of terminals.
The 5 mm pin pitch (center-to-center pin spread) and 4 mm pin length also make these ideal for use with just about any circuit board design. Wire compression is set via the top 4 mm flat head screw. Overall body dimensions (not including pins): 11 mm W x 10.5 mm D x 15 mm H.
  • BrandSure Electronics
  • ModelAA-AA11136
  • Part Number320-3370
  • UPC848864002637
  • Product CategoryAudio Amplifier Boards & Modules
    (1 Reviews)
  • Weight0.07 lbs.
View similar products to the Sure Electronics AA-AA11136 Two Conductor Screw Terminals for Amplifier Boards 10 Pcs.
in the Audio Amplifier Boards & Modules product category.
