Sure Electronics 6x100W TDA7498 Class-D Amplifier Board
Brand:|Model: AA-AB34181
This amplifier board uses three Class-D TDA7498s to generate up to 100W x 6-channels, making it the perfect 5.1 amplifier solution.
List Price$69.99
You Save14%
$59.90
Buy 4+$56.81
Part # 320-307
  • 6 x 100W Class-D amplifier
  • Small footprint for space limited applications
  • Perfect amplifier board for DIY 5.1 amplification
  • Built-in cooling fan and over-temp protection circuit
  • 14 to 39 VDC power supply required
Build your own high-power 5.1 amplifier with this 6-channel amplifier board. Three Class-D TDA7498s are used for extreme efficiency. The small 3.6" wide by 4.8" long footprint allows this amplifier board to be used in many applications were size constraints limit the use of conventional amplifiers. Additionally, separate inputs and outputs make this amplifier board perfect for tri-amplifier use. Just add a 14 to 39 VDC power supply, signal source, and speakers!
A low noise cooling fan is mounted atop the robust heatsink to maximize heat dissipation. Thermal, over/under voltage, and current protection circuits are also included to extend the longevity of the amplifier board. Four fixed gain settings are available to allow for volume control at the source, and dual stereo RCA line-level inputs are pre-attached. Mounting holes are provided as is a 2.1 mm x 5.5 mm power jack for quick connection. Screw-down phoenix-type terminals are included for quick speaker wire connection.
Features:
• Three Class-D TDA7498 amplifier ICs
• Heatsink with attached fan
• Pre-drilled mounting holes
• Over-temperature, over/under voltage, and over current protection circuits
• Phoenix-type speaker terminals
• Six line-level RCA inputs
• Power output (with 36 VDC power supply): 100W x 6 (6 ohms, THD 10%), 80W x 6 (8 ohms, THD 10%), 78W x 6 (6 ohms, THD 1%)
• Frequency response: 22 to 22,000 Hz
• Minimum impedance: 4 ohms
• Recommended power supply: 14 to 39 VDC, 18A regulated
• Fixed gain settings: 25.6 dB, 31.6 dB, 35.1 dB, 37.6 dB
• Power input jack: 2.1 x 5.5 mm, center-positive
• Dimensions: 6" L x 4.5" W x 1.4" H
  • BrandSure Electronics
  • ModelAA-AB34181
  • Part Number320-307
  • UPC844632096716
  • Product CategoryAudio Amplifier Boards & Modules
    (8 Reviews)
  • Weight1.35 lbs.
View similar products to the Sure Electronics 6x100W TDA7498 Class-D Amplifier Board
in the Audio Amplifier Boards & Modules product category.
Sure Electronics 6x100W TDA7498 Class-D Amplifier Board is rated 4.25 out of 5 by 8.
Rated 5 out of 5 by from Great for 5.1 home theaterI paired this amplifier with an ASUS Xonar DX 7.1 Channel Sound Card to provide surround sound for my home theater. Even on its lowest gain setting I can shake the house with the sound card output at 50%. There is no hum, no feedback and the unit runs quite and stays cool even after hours of watching movies.
Date published: 2015-04-15
Rated 5 out of 5 by from HD FM Radio, CD, memory stick playerIt performs very well. IR remote controlled volume controls would be an excellent addition to the unit to add more versatility for volume control to multiple channels for adaptability to surround sound.
Date published: 2014-12-08
Rated 4 out of 5 by from BOOM!I made a 6 channel active Xover boombox with this amp. I used compact 8 in DVC Dayton sub with two of the channels (they don't sell just the driver anymore, but search part# 300-490 and already has a nice box and looks the same :). The other channels power Tang Band mids and tweets (the kind will grills built in). I used a 10in Dayton passive radiator (also discontinued) and an auto 3-Way Clarion crossover. I added a Rolls mini mixer for Mic/Volume duties. I used a high capacity rechargeable 12V battery with a voltage-stepper up to ~35 V so I could get about 200W from the amp+battery or power supply. I did it this way so that I could power the 12V components with the same battery. It is easily the loudest and best sounding battery boombox I can Imagine. Unfortunately, it cuts out at high-ish volume and certainly no where near 600 watts. I don't know if it is the amp or some other issue, but seems to be the amp based on other comments. Still, it works and sounds great, but doesn't seem to offer the power advertized.
Date published: 2014-05-09
Rated 5 out of 5 by from Great amp !Picked up this amp to power a boom box project. I am only using 5 out of 6 channels to power an active setup. I am using an active crossover to derive a stereo two way with single subwoofer. So far I am pleased with the soundThis little amp easily powers the tang band 5 1/4 neo subwoofer, two 4 inch Dayton mid woofer and two vifa textile 1 inch dome tweeter. It is running at 30 volts with a DC boost converter from 12 volt battery bank. As it is only powering small speakers it is running very cool to the touch so I have removed the fan from the heatsink. I played it for several hours with some punishing bass and it remains nice and cool so I will leave the fan off for my application. I imagine if you are running this amp with all channels fully driven it will heat up but for me it is not under serious load. I tested the amp powered from 12 volts and it still has a good solid sound but I recommend a good amount of current at lower voltages. This is a very flexible amp with good channel options. It is very well made with the look and feel of a quality motherboard. The sound quality is pleasing and I can't wait to find more applications to use this multi channel amp for. I am installing some outdoor speakers this year and I may have found my amp solution for that too.
Date published: 2014-03-05
Rated 4 out of 5 by from so far so goodI havent run all 6 channels yet but everything seems to be pumping out pretty good at 8 ohms. Info on these units is spread all over the place, and I've many questions.I'm trying to avoid damaging surges. If I put a power switch on the AC input am I safe in most situations ? Will this help if I remember to turn it on/off ?If I'm not using a channel is it safe to run with :1) no input2) no output3)neitherIs there an adviseable way to hack the power DIPswitch- i.e. a 3 way panel/mount switch that can toggle between on/off/mute(standby) ?I've front-mounted my RCA inputs for various reasons, and now I'm afraid someone will yank one out. This will probably cause an ugly surge. I will either:a)lock the RCA's down somehow.b) think of a way to make a buffer so I can hot-swap inputs on this amp(or switch to a 'mute' status to cut output spike ?)
Date published: 2014-01-22
Rated 5 out of 5 by from excellent valueI've used the Sure Electronics amps for a lot of projects and they have proved both durable and powerful. In one project I needed to deliver a 0.5Hz sine wave at 90W, and it did the job. It is important to note that these things are VERY sensitive to impedance: at 4 ohms with a properly rated power supply they deliver full 100W RMS per channel (sine wave). At 8 ohms, around 55W, and something peculiar: at 6ohm only about 35W. So watch your impedance, feed it plenty of juice and enjoy the incredible savings.
Date published: 2013-10-31
  • 2015-08-03T06:34CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_320-307, PRD, sort_mostRecent
Hey guys, I'd like to use this to give 40W to six 4 ohm full-rangers. Is that possible? If it is, would a 15V, 20A SMPS power supply be sufficient? Thanks!
Asked by: Valou
Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531
Answered by: MattW
Date published: 2015-07-24
what gauge power wire should I use for this amp? I plan on using two SLA 12v batteries for 24v, what gauge wire should I use to connect the batteries to the amp? 18 gauge? 16 Gauge?  14 Gauge? 12 Gauge? 10 Gauge?
Asked by: Amp Question
I would recommend 14 gauge for this application.
Date published: 2015-06-26
Will this amp work with 4 ohm drivers?
Asked by: wolfgang883
Yes.
Date published: 2015-05-26
How am I supposed to achieve 18 A of regulated power...
Asked by: Tner
The voltage needs to be regulated. The power supply needs to be able to supply 18A of current or more for this amplifier.
Date published: 2015-05-06
What is a good power supply for this product?
Asked by: Haig
Part 320-316 would work well.
Answered by: MattW
Date published: 2015-04-24
Does anyone know where can I get a dedicated case for the amplifier?  If there is something already made for the amplifier I prefer it rather than drilling holes in a box.
Asked by: Sunfurry
No, there is not a dedicated case for the amplifier but we do sell project boxes that would work well.http://www.parts-express.com/cat/project-boxes/1450
Answered by: MattW
Date published: 2015-04-29
  • 2015-08-02T09:08CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_41
  • loc_en_US, sid_320-307, PRD, sort_recentQuestionsFirst
Videos
