Sure Electronics 4x100W at 4 Ohm TK2050 Class-T Digital Audio Amplifier Board
Brand:|Model: AA-AB009|Part # 320-302
Based on two TC2000 and four TP2050 chips from Tripath, this Class-T audio amplifier board simplifies the creation of exceptional sounding custom multi-channel systems. NOTE: These amplifier boards accept line audio via the RCA jacks only.
  • Pre-assembled, pre-tested
  • Audiophile quality sound
  • Perfect Class-T architecture
  • High output power
  • Four channels—each up to 100W
  • Ample heat sink
  • Up to 90% efficiency
Based on two TC2000 and four TP2050 chips from Tripath, this Class-T audio amplifier board simplifies the creation of exceptional sounding custom multi-channel systems. Compatible with power supplies ranging from 10V-30V, it can be used in many audio applications. The amplifier has four channels with the same power of up to 100 watts each, resulting in outstanding sound quality and versatility. You can employ any number of channels you like, and leave the others unused. The amplifier is exceptionally well designed, with a lot of power reserve, high fidelity, low distortion, good S/N ratio, high sensitivity, low consumption, and full protection. These ideal characteristics make this amplifier a candidate to become the basic building block of your future high fidelity system, or it can become the element that will upgrade an existing system.
Specifications: • Output power: 30W x 4 @ 6 ohms (<1% THD+N), 40W x 4 @ 8 ohms (<3% THD+N), 100W x 4 @ 4 ohms (<10.0% THD+N) • Frequency response: 20 Hz to 20 kHz (±3 dB) • Signal to noise ratio: 100 dB (A-weighted) • Power supply range: 10V to 30V, maximum 32V • Dimensions (mm): 148.3 L x 134.6 W x 31 H. NOTE: This amplifier board accepts line audio via the RCA jacks only.
  • Special FeaturesClass T,BoardOnlyModule
  • BrandSure Electronics
  • ModelAA-AB009
  • Part Number320-302
  • UPC844632088094
  • Product CategoryElectronic Project Kits
    (19 Reviews)
  • Weight1.8 lbs.
View similar products to the Sure Electronics 4x100W at 4 Ohm TK2050 Class-T Digital Audio Amplifier Board
in the Electronic Project Kits product category.
