Sure Electronics 2x300W TAS5630 Class-D Amplifier Board
Brand:|Model: AA-AB32191
At 6 watts per dollar, this stereo Class-D amplifier board is a tremendous value pumping out up to 300W per channel. Perfect for use with subwoofers or as a high-end, two-channel critical listening amplifier. 25 to 50 VDC power supply required.
List Price$119.99
You Save50%
Buy 4+$56.98
Part # 320-309
  • 2 x 300W of Class-D power
  • Great for use as a subwoofer amp and with tactile transducers
  • Over-engineered protection circuits
  • Robust heatsink with two-stage fan
  • Requires 25 to 50 VDC power supply
Just one look at the power input terminals and you will know that this amplifier board means business! A Class-D Texas Instruments TAS5630 with PurePath™ HD enabled integrated feedback is used to deliver 300W to two channels, effortlessly and efficiently. This amplifier board works amazingly well with both low sensitivity speakers and subwoofers.
A robust heatsink, two-stage cooling fan, as well as protection circuits to protect against over/under voltage, over current, short circuit, and over temperature conditions are built-in for years of enjoyment. Four fixed gain settings allow you to match the amplifier to your source, and use your source as the volume control. A 25 to 50 VDC power supply is required (sold separately).
Note: The minimum recommended wire gauge to be used for power is 16 AWG.
• Class-D Texas Instruments TAS5630 with PurePath™ HD enabled integrated feedback
• Robust heatsink with two-stage cooling fan
• Pre-drilled mounting holes
• Over/under voltage, over current, short circuit, and over temperature protection circuits
• Click and pop noise reduction
• Phoenix-type speaker terminals
• Two line-level RCA inputs
• Large screw-down power input terminals
• Power output (with 50 VDC power supply): 300W x 2 (4 ohms, THD 10%), 160W x 2 (8 ohms, THD 10%), 240W x 2 (4 ohms, THD 1%)
• Minimum impedance: 2 ohms
• Frequency response: 20 to 20,000 Hz (±3 dB)
• Recommended power supply: 25 to 50 VDC, 16A regulated
• Fixed gain settings: 23 dB, 29 dB, 33 dB, 35 dB
• Power input jack: 2.5 x 5.5 mm, center-positive
• Dimensions: 6" L x 4.7" W x 2.1" H
  • BrandSure Electronics
  • ModelAA-AB32191
  • Part Number320-309
  • UPC844632096709
  • Product CategoryAudio Amplifier Boards & Modules
    (4 Reviews)
  • Weight1.2 lbs.
View similar products to the Sure Electronics 2x300W TAS5630 Class-D Amplifier Board
in the Audio Amplifier Boards & Modules product category.
Sure Electronics 2x300W TAS5630 Class-D Amplifier Board is rated 4.75 out of 5 by 4.
Rated 4 out of 5 by from it definitely needs a large power supplyI bought 2 of these, not really sure where to use them. Still don't know. I also bought 2 of the 300 watt DC voltage boosters to go with them. I sorta kinda thought I might make a pair of powered main speakers, but when I hooked up a 24 volt supply, it was obvious it needed a 48-50 volt supply. I'm still in process. They work as advertised, appear to be excellent quality.
Date published: 2014-04-02
Rated 5 out of 5 by from Very Well-BuiltThis amp does exactly what it's advertised to do. It WILL pump 2X300 watts into a 4 ohm load as long as your power supply is strong enough. All of the electronic components are very secure. My favorite feature is the built-in circuit breaker that kicks in within seconds of an overloaded circuit or in the event of the power supply pushing more than 50 volts. I'd recommend this amp board to anyone looking for a simple power amp with a very small footprint.
Date published: 2013-12-29
Rated 5 out of 5 by from very good amp boardI got a few of these amps before and they are loud. I'm using the amp with a 48 VDC 7.3A 350W Switching Power Supply and its still rocks.
Date published: 2013-07-30
Rated 5 out of 5 by from Nice clean and powerful amplifier!I had a dead stereo power amplifier and wanted to "rebuild" it into a working amp again. So I used the existing toroidal power transformer, a pair of 47000 uF, 50 volt capacitors and the 2x300W TAS5630 Class-D Amplifier Board.I powered up the amp board - it just worked. The board sounds nice and clean. Lows pound through, and I can hear the highs crystal clear without any distortion. I can crank it up as far as my limited power supply will allow and the board just works - and works cleanly.I know the board is Class-D and efficient, but wow... it doesn't even get warm when cranking about 150 watts per channel into a pair of 8 ohm dummy loads. I can't get more than that now (explained next).Last thing I need to do is upgrade the power transformer. The old amp only has a 25.8 volt transformer which gives me about 35 volts at the capacitors (Vrms * 1.414). I'll use a 40 volt transformer with a higher VA rating to power the amplifier board to it's fullest.
Date published: 2013-03-18
  • 2015-10-06T06:17CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_320-309, PRD, sort_mostRecent
please email  for a prompt reply.
If I wanted to limit this amp to 150w per channel rms at 4ohm an 1%thd, what power supply would be needed?
Asked by: Cadrion
Which kind of step-up converter shall i use when i need this AMP to be powered from 12 volt battaries?
Asked by: Astybe
The Sure model below would be a good choice.
Date published: 2015-07-13
Would this power supply work? 48 VDC 3.3A 150W Regulated Switching Power Supply ? What would be the bare minimum power supply required that would give me 250 watts output continuously?
Asked by: valpd
You will need a t least a 6 Amp output rating on your power supply for a continuous output of 250 Watts assuming an efficiency of about 85% . I would recommend more.  Not a good idea to run a power supply at its maximum rating continuously.
Answered by: Farmer Gene
Date published: 2015-09-27
will this power supply work with this amp? 48 VDC 12.5A 600W Regulated Power Supply
Asked by: valpd
Answered by: TomI
i have 300w RMS on my speakers they should mach up just fine?
Asked by: shanebou24
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, or 800-338-0531 x1.
Is it possible to run this amplifier in bridged mode?
Asked by: THR2
No, this amplifier is not bridgeable.
  • 2015-10-06T08:38CST
  • co_hasquestionsanswers, tq_24
  • loc_en_US, sid_320-309, PRD, sort_recentQuestionsFirst
Get Sales Flyer
