Sure Electronics 2x100W at 4 Ohm TK2050 Class-T Audio Amplifier Board Only
Brand:|Model: AA-AB32186|Part # 320-334
This audiophile-grade amplifier board was designed using the critically acclaimed TK2050 chipset for efficient power output, just add a 12 to 32 volt DC power supply.
Comparable Items In Stock:
Part # 320-334
  • Line-level audio signal input
  • Mounting holes facilitate installation and fixing
  • Excellent heatsink and powerful cooling fan
  • Over/under voltage turn off
  • Over-current protection
This amplifier board is designed for the audio enthusiast who would rather build it than buy it. Each board has been thoroughly engineered, tested, and manufactured to above industry standards. Innovative features have been implemented into the board designs which have exceptional performance and would look as great in an art gallery as they will in your next audio project. The 2 x 100 watt amplifier board integrates Tripath's high performance TC2000 and TK2050 chips. Powered by any DC voltage from 10V to 32V, this high efficiency design is capable of driving 4 ohm or 8 ohm speakers with up to 100 watts per channel. Thermal management is maintained through the use of an temperature activated fan.
Features and Specifications:
  • Size: 148.30 (L) × 106.80 (W) × 35.50 (H) ±0.2 mm
  • A perfect "Class D" architecture
  • Wide power supply range: 12V to 30V, maximum 32V
  • Frequency response: 20 Hz to 20 kHz (±3 dB)
  • Signal/noise ratio: 100 dB (A-weighted)
  • High output power:
        30W @ 6Ω, < 1% THD+N
        40W @ 8Ω, < 3% THD+N
        100W @ 4Ω, < 10.0% THD+N
  • High efficiency:
        86% @ 60W 8Ω
        82% @ 46W 6Ω
        90% @ 100W 4Ω
  • Audiophile quality sound:
        0.007% THD+N @ 30W 8Ω
        0.005% THD+N @ 70W 4Ω
  • Line level audio signal input
  • Several wiring methods facilitate connection
  • Excellent heat sink and powerful cooling fan on TK2050 eliminate your worry on heat dissipation
  • Over/under voltage turn-off
  • Over-temperature protection
  • BrandParts Express
  • ModelAA-AB32186
  • Part Number320-334
  • UPC844632095771
  • Product CategoryAudio Amplifier Boards & Modules
    (16 Reviews)
  • Weight0.65 lbs.
View similar products to the Sure Electronics 2x100W at 4 Ohm TK2050 Class-T Audio Amplifier Board Only
in the Audio Amplifier Boards & Modules product category.
