24-Key LED Control Unit with IR Remote Control
Sure Electronics 24-Key LED Control Unit with IR Remote Control
Brand:| Model: LE-LL19111
This LED control unit allows you to create effects that are limited only by your imagination. Designed to work with up to 5 meters of RGB LED light strips.
  • Great for product displays or window treatments
  • Drives up to 5 meters of RGB LED strips
  • IR remote control included
073-002
Weight: 0.15 lbs.
IN STOCK
List Price$9.99
You Save40%
$5.98
Buy 4-up$5.68
Part # 073-002
Create custom lighting effects with this 24-key IR remote control and LED control unit, that's specifically designed to work with 12 VDC RGB LED light strips. Adjust brightness, color, fade in/out, and flash rate. Supports up to five meters of RGB LED light strips. Other tri-color, common anode LEDs may be used if configured to work with 12 VDC supply voltage. IR remote control uses a CR2025 battery (included).
Note: Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Specifications: • Power requirements: 12 VDC, 2A (minimum recommended), 12 VDC, 6A (with max current draw from each of three LEDs) • Power input: 2.1 x 5.5 mm, center positive • Output: Three CMOS drain-open output • Connection type: Common anode • Control unit dimensions: 63 mm (2.48") L x 35 mm (1.38") W x 22 mm (0.87") H.
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)OffOn
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark orchid7 color flash
Static dark yellowStatic cyanStatic magentaAll fade out & fade in
Static yellowStatic light blueStatic pink7 color fade
Static light yellowStatic sky blueStatic purple3 color smooth transition
  • BrandSure Electronics
  • ModelLE-LL19111
  • Part Number073-002
  • UPC844632093357
  • Product CategoryAccent & Party Lighting
    (4 Reviews)
  • Weight0.15 lbs.
View similar products to the Sure Electronics 24-Key LED Control Unit with IR Remote Control
in the Accent & Party Lighting product category.
24-Key LED Control Unit with IR Remote Control is rated 4.5 out of 5 by 4.
Rated 4 out of 5 by from rgb remote and controllerI bought 5 of these and they work great except one of them didn't have a red color. No biggie. They'll refund any bad ones without a problem.
Date published: 2015-01-04
Rated 4 out of 5 by from Great little controllerIt's great for the price and it will run off a 9v battery, although a little bit dimmer, not a problem at all if that's all you have. I'm running 18 RGB LEDs off one box at 9v with no problems. (maybe white isn't white enough)I didn't like the plug so I cut it off and soldered directly to my LEDs but the wire color in the cable DOES NOT match the color output. Red and green are switched! So if you have a custom install you can either pop open the box, which is easy, and solder the wires or just swap red and green wires at your LEDs.
Date published: 2013-09-05
Rated 5 out of 5 by from Great product, great priceYou just can't beat it for the price. At $5.00, it gives you basic control of your strip lighting and does a pretty decent job of it. Worth having just to test the lights out!
Date published: 2012-05-09
Rated 5 out of 5 by from Nice RemoteAfter I finally received the Power Supply I hooked it up and love it. Took a bit to figure out all the features.
Date published: 2012-01-20
  • 2015-07-07T07:07CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_073-002, PRD, sort_mostRecent
hooked up lights have 12vdc coming from transformer feeding led transformer and then to lights but lights wont come on . is there any special programming from remote to turn lights on?
Asked by: ph electrical
no. Just the power button to turn them on, then color or pattern select. works with lavolta RBG light strips.
Answered by: TomI
Date published: 2015-03-02
I want to put this in a video game that will be powered off every night. Will I have to reprogram it every day or will it hold the settings overnight? I will be using the 12 volt line from the games power supply to power this controller.
Asked by: Buddy B
The 24 key remote doesn't offer programming. The 44 key remote does and yes it will hold its memory.
Answered by: TomI
Date published: 2015-02-03
Does the light controller come with the light strips or do you have to purchase those separately?
Asked by: Ozzyboy316
The strips are sold separately.
Date published: 2014-11-17
Can this be used with the Individual Red Green and Blue SMD 3528 LEDs 5m Tape Lighting Strip 12 VDC Waterproof 100 Each Color?
Asked by: Peri
Yes this will work for those strips.
Can these controllers be mounted in an outdoor application indirectly exposed to outdoor elements?
Asked by: Todd1452
The controllers are not designed to be in the elements even if they are protected from rain. The elements in general will have an affect on them over time and probably cause them to stop functioning properly.
If the blue light turns on automatically, and the remote doesn't respond in result doing nothing, nor turning off or change color. What do I do?
Asked by: Williev305
Did you pull the little plastic strip out of the battery compartment on the remote? This prevents the battery from making contact while in packaging. If you have done this you may have a defective remote and you will need to call our customer service for a replacement: 1-800-338-0531 x2
  • 2015-07-07T08:04CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_073-002, PRD, sort_recentQuestionsFirst
Customer projects that include: Sure Electronics 24-Key LED Control Unit with IR Remote Control
