Super Bright White 5mm LED 17000 mcd 100 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13111|Part # 073-022
This package includes 100 super bright white LEDs together with 200 voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
List Price$16.99
You Save51%
$8.25
Buy 4+$7.40
Part # 073-022
  • Design your own lightshow or flashlight
  • Includes 200 voltage dropping resistors (100 for 5 VDC, 100 for 12 VDC)
  • Waterproof and shatterproof
Design your own flashlight with super bright white LEDs. Ideal for use with fog machines, custom interior illumination, or as signal indicators; this LED kit includes voltage dropping resistors for use with 5 or 12 VDC source voltages. Extreme heat and vibration won't deter these LEDs, and their waterproof and shatterproof design allows them to be used just about anywhere.
Specifications: • Size: 5 mm • Lens color: Water clear • Forward current: 20 mA continuous, 50 mA peak • Forward voltage: 3.0 to 3.2 VDC • Viewing angle: 5° to 25° • Luminous intensity: 17000 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorWhite
  • Lens Type / ColorWater Clear
  • Luminous Intensity17000 mcd
  • Application TypeSteady
  • BrandSure Electronics
  • ModelDC-LE13111
  • Part Number073-022
  • UPC844632093456
  • Product CategoryLEDs
    (14 Reviews)
  • Weight0.1 lbs.
View similar products to the Super Bright White 5mm LED 17000 mcd 100 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
Super Bright White 5mm LED 17000 mcd 100 Piece Kit with Voltage Dropping Resistors is rated 4.6429 out of 5 by 14.
Rated 4 out of 5 by from Great valueBought these to repair a bed-side lamp that used an array of 20 LEDs. These were inexpensive and came with current limiting resistors.Specific comments:- some of these LEDs got reversed. The packaging and wire lead lengths indicated one polarity, but in reality it was the reverse polarity. I was testing them as I put them in the array, so I figured it out, but it's something to watch for.- These have a relatively high forward voltage drop (3.0 - 3.2 V) which limited my ability to build a 4x5 array with a 12V supply; I ended up building a 6x3 array instead. I guess that's a common forward voltage drop for white LEDs, but it would have been lovely if they were in the 2 to 2.5 V range instead.My project was a success, and I'd give the parts a thumbs up.
Date published: 2015-10-01
Rated 5 out of 5 by from Extreme brigtnessI bought these for use in a medical diagnostic device where we needed to simulate office lighting, outside on a cloudy day and outside in bright sunlight. Obviously, we needed to use a few of these and change the drive current for our brightness levels, but they came through in the end. A great price and fast shipping!
Date published: 2015-05-27
Rated 5 out of 5 by from led that is bright and works wellfully functional with hearty leads that solder well and the led is bright
Date published: 2015-05-06
Rated 5 out of 5 by from bright little LEDsI'm using my bright white LEDs to update my emergency lighting for the stairwell in my house. I run them on my Ham radio station batteries (12V@ 600Ah) so that they are always on without any extra attention. When the tornado sirens sound in the middle of the night with the power already off, we can see to get down the stairs to our safe room in the basement. I used to use conventional lights, but got tired of their short life and higher current draw. I use 8 LEDs in each fixture wired as 4 in series and two groups in parallel. Even with the 10 foot ceiling, we can easily see the steps!
Date published: 2015-02-02
Rated 5 out of 5 by from Awsome LED lightsSeriously sweet kit. Comes with everything as advertised. 470 ohm resistors are for 12 Vdc circuit and 100 ohm are used for 5 Vdc circuit. I used 470 ohm resistor and 3 led bulbs to make one circuit then wired 5 of these together to make lights for one door under cabinets. Heat shrink tubing keeps everything together nice and neat. Wife complained that she couldn't see even with all lights on so I designed and built this to make her happy. When she is happy....... everyone's happy! YAY!
Date published: 2014-10-26
Rated 4 out of 5 by from work great!I bought these to replace burnt out led Xmas lights. They are too large for that application but I did try some other applications that worked well. I will be ordering the 3m leds to see if they will fit the Xmas light application
Date published: 2014-01-23
  • 2016-02-06T07:38CST
  • co_hasreviews, tv_0, tr_14
  • loc_en_US, sid_073-022, PRD, sort_mostRecent
what size are these? 5mm?
Asked by: james81
Yes, these are indeed 5mm
Answered by: Chrisf
Date published: 2014-02-07
Dimmable
Is this dimmable if attached to a 12v dimming circuit (like a car dashboard supply)?
Asked by: briands
As long as you do not exceed the rated voltage and use the current resistor you can get some dim ability from themI replaced two in a dash circuit with good results each one with its resistor attachedSide note if you replace all your dash lights with these it will not work as the dimmer resistor does not have enough drop you would have better luck with a dimable led power unit
Answered by: Knowitfixit
Date published: 2013-04-24
Lumens
What is the formula for conversion to lumens ?
Asked by: Retiredtech
Check this out: http://led.linear1.org/lumen.wiz/This site may help you get an approximate answer.
Answered by: Bryan
Date published: 2012-07-05
mcd ??
What exactly does this mean ?? Thanks. RG
Millicandelas - a measure of luminous intensity. Conversion to lumens is possible if you know the beam angle of the LED.
Answered by: KC Jayhawk
Date published: 2012-06-25
What are the ohm values on the 2 different reisistors?
Asked by: whack job bob
The included resistors are 100Ω and 470Ω.
Answered by: RussR
Date published: 2012-05-18
  • 2016-02-06T08:42CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_073-022, PRD, sort_recentQuestionsFirst
