Super Bright White 5mm LED 17000 mcd 10 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13128|Part # 073-023
This package includes 10 super bright white LEDs together with voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
List Price$4.99
You Save40%
$2.98
Buy 4+$2.70
Part # 073-023
  • Design your own flashlight
  • Includes voltage dropping resistors 5 VDC and 12 VDC source voltages
  • Waterproof and shatterproof
  • Perfect for product prototyping
Design your own flashlight with super bright white LEDs. Ideal for use with fog machines, custom interior illumination, or as signal indicators; this LED kit includes voltage dropping resistors for use with 5 or 12 VDC source voltages. Extreme heat and vibration won't deter these LEDs, and their waterproof and shatterproof design allows them to be used just about anywhere.
Specifications: • Size: 5 mm • Lens color: Water clear • Forward current: 20 mA continuous, 50 mA peak • Forward voltage: 3.0 to 3.2 VDC • Viewing angle: 5° to 25° • Luminous intensity: 17000 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorWhite
  • Lens Type / ColorWater Clear
  • Luminous Intensity17000 mcd
  • Application TypeSteady
  • BrandSure Electronics
  • ModelDC-LE13128
  • Part Number073-023
  • UPC848864000268
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.01 lbs.
View similar products to the Super Bright White 5mm LED 17000 mcd 10 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
Super Bright White 5mm LED 17000 mcd 10 Piece Kit with Voltage Dropping Resistors is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Awesome!I bought four of these kits so I could make my own artificial lighting for a video project. This kit was very well planned! Also, the LED's work just as they should, they lack the purple/blue tinge that so many white LED's seem to have.
Date published: 2012-11-08
  • 2016-02-06T07:38CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-023, PRD, sort_mostRecent
If I'm putting up to 27 of these on 1 circuit, how many amps total would they draw, and could I use just 1 voltage dropping resistor, or does each LED needs its own resistor?
Asked by: ff25m2
For use with the recommended 5 VDC or 12 VDC source voltage each LED needs its own resistor.  Don't be tempted to use a single resistor for multiple LEDs in parallel.The purpose of the resistors is not really "dropping the voltage" like PE says, the purpose is setting the LED current, i.e. making the supply voltage source into a constant current source as required by the LED.Using a 5VDC supply and the 100 ohm resistors included with the kit the current per device will be (5.0V - Vforward)/100 ohms = (5.0V - 3.0V)/100 ohms = 20mA.  Using a 12V supply and the included 470 ohm resistors the current per device will be (12.0V - 3.0V) / 470 ohms = 19mA.
Answered by: sjj000
Date published: 2015-05-11
For Super Brite White LEDs (5mm 17000 mcd), dropping resistors are supplied for 5VDC and 12VDC. What dropping resistor is required for 6VDC input?
Asked by: Midnight Cowboy
I would recommend a 60 ohm, 1/2 watt resistor for an input voltage of 6 VDC.
Date published: 2014-11-26
How many leds do I need to replace a 75W bulp and what would be a good 12V transformer for them?
Asked by: Tobi
You can use as few or as many as you want as long as you use the appropriate resistor to drop the voltage.
Date published: 2012-11-21
  • 2016-02-06T08:42CST
  • loc_en_US, sid_073-023, PRD, sort_recentQuestionsFirst
