073-118_ALT_0
Super Bright Blue 5mm LED 3000 mcd 10 Piece Kit with Voltage Dropping Resistors
Brand:| Model: DC-LE13129
This package includes 10 bright blue LEDs together with voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
  • Includes voltage dropping resistors
  • Shatterproof and waterproof design
  • Great for custom lighting
073-118
Weight: 0.01 lbs.
IN STOCK
List Price$4.99
You Save40%
$2.98
Buy 4-up$2.70
Part # 073-118
Design your own lightshow with super bright blue LEDs. Ideal for use with fog machines, custom interior illumination, or as signal indicators; this LED kit includes voltage dropping resistors for use with 5 or 12 VDC source voltages. Extreme heat and vibration won't deter these LEDs, and their waterproof and shatterproof design allows them to be used just about anywhere.
Specifications: • Size: 5 mm • Lens color: Water clear • Forward current: 20 mA continuous, 50 mA peak • Peak wavelength: 470 nm • Forward voltage: 3.2 to 3.4 VDC • Viewing angle: 5° to 25° • Luminous intensity: 3000 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorBlue
  • Lens Type / ColorWater Clear
  • Luminous Intensity3000 mcd
  • Application TypeSteady
  • BrandParts Express
  • ModelDC-LE13129
  • Part Number073-118
  • UPC848864000343
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.01 lbs.
View similar products to the Super Bright Blue 5mm LED 3000 mcd 10 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
Super Bright Blue 5mm LED 3000 mcd 10 Piece Kit with Voltage Dropping Resistors is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Perfect replacements for my Audiobahn amp.These matched the voltage, size, color & brightness of the blue LEDs that went bad in my amp. Didnt need to use the resistors. Forward voltage was perfect. My 10 pack only had 9. I'm not complaining. Still a smoking deal. Fast shipping made up for it.
Date published: 2013-08-17
  • 2015-03-04T08:20CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-118, PRD, sort_mostRecent
How to install in a fan?
I bought a Nesus 12v 92mm PWM fan (not from Parts Express). I thought it came wiht LED's but it did not. It has the holes already drilled and I think there is even spots of the circit board for the LED wires. I'm not very good wiht circit board so I need help here.I want these blue LEDs but can I just sodder them directly to the circit board or will I have to add the resistors. I don't want to break anything or cause damage to my motherboard.If it helps the fan is going in my Xbox 360 slim. I also hope the picture helps.Thanks.
Asked by: ricky jay
I am not familiar with these fans. You will need to determine what the voltage and amp rating that these have available to drive the LED. At the least a volt meter across the terminals you suspect would get an idea.
Answered by: Chrisf
Date published: 2013-03-26
  • 2015-03-04T09:07CST
  • loc_en_US, sid_073-118, PRD, sort_recentQuestionsFirst
Customer projects that include: Super Bright Blue 5mm LED 3000 mcd 10 Piece Kit with Voltage Dropping Resistors
