290-262_ALT_0
290-262_ALT_1
Studio Pro WH10 10" Woofer Accordian Surround
Brand:| Model: WH10
Quality replacement woofers for old, blown drivers in P.A. and musical instrument speaker cabinets. These rugged, "road-ready" woofers feature ribbed paper cones, treated cloth accordian surrounds, high power-handling capability, huge strontium magnets and bumped backplates.
290-262
Weight: 4.06 lbs.
IN STOCK
List Price$46.99
You Save67%
$15.48
Buy 4-up$14.48
Part # 290-262
  • Nominal Diameter10"
  • Power Handling (RMS)125 Watts
  • Power Handling (max)250 Watts
  • Impedance8 ohms
  • Frequency Response74 to 5,000 Hz
  • Sensitivity89.3 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Magnet Weight25 oz.
  • Resonant Frequency (Fs)74.8 Hz
  • DC Resistance (Re)8 ohms
  • Mechanical Q (Qms)11.18
  • Electromagnetic Q (Qes)2.38
  • Total Q (Qts)1.96
  • Compliance Equivalent Volume (Vas)1.12 ft.³
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.25"
  • Baffle Cutout Diameter9.25"
  • Depth3.5"
  • # Mounting Holes8
  • Sealed Volume0.93 ft.³
  • Sealed F374 Hz
  • * Enclosure volume/F3s based on BassBox "optimum" calculations-
Optimum Cabinet Size *
  • Sealed F374 Hz
  • BrandPyramid
  • ModelWH10
  • Part Number290-262
  • UPC068888703673
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (26 Reviews)
  • Weight4.06 lbs.
Pyle PPA10 10" PA Speaker
Part # 292-214
View similar products to the Studio Pro WH10 10" Woofer Accordian Surround
in the Woofers, Subwoofers & Midrange Speakers product category.
Studio Pro WH10 10" Woofer Accordian Surround is rated 4.1538 out of 5 by 26.
Rated 4 out of 5 by from Pyramid Studio Pro WH10 10" Woofervery good speaker, excellent price covers the full range with clear reproducti
Date published: 2013-11-06
Rated 4 out of 5 by from Very impressive for the price!Bought a pair of these, the Goldwood ported subwoofer boxes, 2(ea) Goldwood tweeters in series, 2 4uF caps, and 1/4 cups and sockets for a $120. I needed to get a flatter curve on my EQ to save watts, which it did. 4 times louder than the SA 10 in. monitors I had paired with my old EV 1502s. At only $60 each, you could probably build a fairly decent array with these. I also tried them alone with a 250 wpc McIntosh. Not bad at all. A tiny bit of distortion somewhere. Probably the frames. But still, quite acceptable for PA designed speakers. Also, the sensitivity is amazing for the price. AND all shipped well and fast delivery!
Date published: 2013-05-12
Rated 5 out of 5 by from Replacements for House SpeakersThis may be a "no, no", but I bought these to replace some blown Curtis-Mathes speakers. I am using these as reference monitors in my home studio and I needed something that could handle the power put out by my amp.The description listed these as able to handle 200watts, but the speakers have "300 watts" printed on them.These speakers are clear and loud and I am VERY pleased with my purchase. For the price, I'm blown away.I am sure that "purists" and "true audiophiles" will say that these suck (or whatever), but as a man on a budget who needed what he needed at a time when these were in my range....BUY THESE...THEY WORK AND THEY SOUND GREAT.
Date published: 2013-01-16
Rated 5 out of 5 by from Great speaker for the price!!!I just purchased a pair of these to replace some old ones in my speakers and they sound awsome! They are just fine for me. And you can not beat the service...I ordered them and got them the next day...great job Parts Express!!!
Date published: 2011-02-17
Rated 4 out of 5 by from Sounds Good through a Custom CabI built two cabs and put 2 of these 10"s, and 2 of the StudioPro 8"s in each of them. I play guitar through an effects pedal, eq, and power amp to these speakers and really dig the way it sounds. The eq was all I needed to dial it in. For the money ($60 per cab), I feel like I got a good deal.
Rated 2 out of 5 by from not a good replacement for Kustom speakersI bought a pair of these to replace the 10" drivers in my KC10's and they dont even come close. Too much bass and you will cook them. you would be better off using a car audio woofer as they can handle the distortion of the Kustom head better
Date published: 2013-07-30
Will these be OK in a sealed cab, or do I really need to port it?
Asked by: The Kirbster
The TSP of this driver dictate that a vented box would be downright aweful. A large sealed box or low power infinite baffle would be the way to go.
Answered by: Matt
Date published: 2011-11-25
What size speaker cab with 290-262 for 4 string bass guitar?
I already own a pair of these speakers (290-262). I intend to build a pair of 1x10 cabs for them, to play bass guitar thru. I need suggestions on cabinet volume, porting info, ANY info to make these as good as they can be for reproducing the 4 string bass guitar's frequency range (aprox. 28 Hz thru 2kHz)
It really depends on if you want tight crisp response, or long drawn out rumbling bass. For tight crisp bass I would recommend a smaller box, between 1.0-1.5 cubic feet, not ported, with a light coating of polyfill in the box. I would think that a 14 deep, by 15 tall, by 15 wide exterior dimension using 3/4 inch mdf would give you good crisp reproduction, but beware of overpowering this box, distortion will be very noticeable. For lower lows you would want to go with a bigger box, such as 24 tall, by 15 deep, by 15 wide exterior dimension with the woofer mounted in the upper half of the box with two 3 inch ports, 12 inches deep, in the lower corner front of the box. Again with this box use polyfill, but be very generous with it in this box. Don't pack it in, but a nice fluffy will. I hope that this helps. Cheers!
Answered by: Barny D
Date published: 2013-01-22
Would these work in a sealed box 26x16x11 connected to a 130watt stereo chorus amp?
Asked by: bigbabee
Yes these will work in that volume. I would recommend some sort of high pass filter to help prevent excursion damage at higher power levels.
Date published: 2013-12-30
Customer projects that include: Studio Pro WH10 10" Woofer Accordian Surround
