StreetWires ZN3KI-08 ZeroNoise 3 Series 8 AWG Amp Kit Red/Black with Interconnects
Brand:|Model: ZN3KI-08|Part # 263-1753
ZN3 ZeroNoise amp kits from StreetWires includes nearly everything you need to deliver pure current to your amplifier without the voltage drop experienced with other brand cables.
  • CEA-2015 compliant for true wire gauge
  • Includes power and ground cables as well as RCA interconnects
  • Connectors, fuse holder, and fuse are included
  • Designed for 200 to 400W systems
StreetWires' ZN3 ZeroNoise amplifier kits use rope-lay cable construction to transfer electrical current from your car battery to your amplifiers without significant voltage drop. The flexible, translucent cable jacket can cable protection from harsh under-hood chemicals such as battery acid, oil, and gasoline.
ZN3 ZeroNoise power cable meets the strict CEA-2015 American Wire Gauge cabling standards, and the rope-lay wire construction prevents kinking... essential for professional installations. To find out if you're getting the most out of your amplifier with your power cable, check out the interactive PowerWire Display from StreetWires. Copper covered aluminum wire (CCAW) is used for the power and ground cable for a lightweight connection without affecting power transfer. This 8 AWG amplifier kit is perfect for 200 to 400 watt systems.
The ZN3KI-08 amplifier kit includes a 16.4 foot set of ZeroNoise 3 Series stereo RCA interconnects that feature twisted pair construction for noise rejection, sure grip connector body for ease of installation, as well as split center pin and connector sleeve for a tight fit.
Kit Includes:
• 18 ft. of 8 AWG red power cable
• 4 ft. of 8 AWG black ground cable
• 16 ft. of 18 AWG remote turn-on wire
• One fuseholder with 60A fuse
• One 8 AWG 3/16" ring terminal
• One 8 AWG 5/16" ring terminal
• Two 8 AWG spade connectors
• One 18 AWG butt splice
• One 18 AWG spade connector
• Four cable ties
• One 16.4 foot ZeroNoise 3 Series stereo RCA interconnect
  • BrandStreetWires
  • ModelZN3KI-08
  • Part Number263-1753
  • UPC715442143634
  • Product CategoryCar Amplifier Wiring Kits
  • Weight1.85 lbs.
View similar products to the StreetWires ZN3KI-08 ZeroNoise 3 Series 8 AWG Amp Kit Red/Black with Interconnects
in the Car Amplifier Wiring Kits product category.
