StreetWires RTC4L 4 AWG Crimp Ring 8mm 4 Pcs.
Brand:|Model: RTC4L|Part # 263-645
For use with 4 AWG wire. 8 mm hole diameter (fits 5/16" stud).
List Price$9.95
You Save18%
$8.11
Part # 263-645
StreetWires crimp ring terminals feature tube type construction for cleaner more professional termination and silver pulse plating to resist finish damage. For use with 4 AWG wire. 8 mm hole diameter (fits 5/16" stud). Contains four crimp rings with red and black heat shrink.
  • Connector TypeRing
  • Wire Gauge4 AWG
  • Terminal / Stud Size5/16"
  • BrandStreetWires
  • ModelRTC4L
  • Part Number263-645
  • UPC715442151059
  • Product CategoryPower Cable Ring Terminals
  • Unit of MeasurePK
    (2 Reviews)
  • Weight0.14 lbs.
View similar products to the StreetWires RTC4L 4 AWG Crimp Ring 8mm 4 Pcs.
in the Power Cable Ring Terminals product category.
StreetWires RTC4L 4 AWG Crimp Ring 8mm 4 Pcs. is rated 3.0 out of 5 by 2.
Rated 2 out of 5 by from Its okay.Nickel coating flakes off.
Date published: 2010-03-11
Rated 4 out of 5 by from Good quality, but a bit expensive.These are very good connectors. They work perfectly with 4 ga. wire. However, they are a bit difficult to crimp. You either need the proper crimping tool (larger than what you'd find at Radio Shack) or pliers that have enough leverage to compress the connector onto the wire. I destroyed one of these by not crimping it properly. When I tested my connection by pulling the wire came out! It takes a lot of force to compress this connector, but when done right it is excellent.
Date published: 2009-03-09
  • 2016-02-07T06:48CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_263-645, PRD, sort_mostRecent
