StreetWires BASMS Side Mount Adapter Short
Brand:|Model: BASMS|Part # 263-634
StreetWires battery post adapters are machined from billet brass and are silver pulse plated for increased conductivity and corrosion resistance.
StreetWires battery post adapters are machined from billet brass and are silver pulse plated for increased conductivity and corrosion resistance. Sold individually.
  • BrandStreetWires
  • ModelBASMS
  • Part Number263-634
  • UPC715442151349
  • Product CategoryBattery Clamps & Grounding Blocks
    (5 Reviews)
  • Weight0.12 lbs.
View similar products to the StreetWires BASMS Side Mount Adapter Short
in the Battery Clamps & Grounding Blocks product category.
StreetWires BASMS Side Mount Adapter Short is rated 4.6 out of 5 by 5.
Rated 4 out of 5 by from good productThis is a very good product and served the perfect purpose for my needs. Well made and worked well. Couldn't find this bolt any place local. Good price but brutal shipping when you need only one or two cheap items.
Date published: 2013-02-25
Rated 5 out of 5 by from Power TapWhen you need to add stuff to your battery, they do the job great. It took me less than 10 minutes to install this item (due to the fact we had snow on the ground and my fingers ware cold).Anyone adding sound equipment or inverters to their car would love this as well. I installed this on a 1998 Buick Century.
Date published: 2008-12-27
Rated 5 out of 5 by from Fits Optima side terminalsFits the red top I have in my Jeep. Now I can add accessories easily without having to tap off the main terminals.
Date published: 2008-09-11
Rated 5 out of 5 by from Improved Design !I have used several auto battery terminal adapters over the past 20 years and found most to have soft metal threads that cause the adapter to loosen over time. A loose adapter will cause a high resistance connection under high current, such as cranking the engine. This adapter fits the Optima Red Top and Yellow Top batteries and does not require periodic tightening. When using this adapter with GM OEM battery cables, the same amount of thread is available as with the OEM side mount post which means you won't damage the battery with threads that are too long or too short. I have had two of these terminals in place on my truck for one year now, and am very satisfied with their performance.
Date published: 2007-09-16
Rated 4 out of 5 by from Great functionalityfor being so simple, it does a great job for a clean install. Fit like a charm and allows for 4ga wire to look "factory"
Date published: 2007-09-11
  • 2016-01-27T06:35CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_263-634, PRD, sort_mostRecent
Will these fit any battery? My battery has top posts but I was wondering if I could use this to easily stack ring terminals.
Asked by: G.S.
This wouldn't work for your application The threaded side is too big to fit through the top mount posts. There are options out there if you want a gold plated or otherwise esoteric option. If you want to do it cheaply, just locate a bolt and nut that fits and you can stack rings on that
Answered by: Musgofasa
Date published: 2012-02-21
  • 2016-01-27T07:06CST
  • loc_en_US, sid_263-634, PRD, sort_recentQuestionsFirst
