129-002_ALT_0
129-002_ALT_1
129-002_ALT_2
129-002_ALT_3
129-002_ALT_5
Streetglow OPTX 12 VDC 2.5A AC Adapter Power Supply with Distribution Block
Brand:|Part # 129-002
The Streetglow OPTX 12 VDC 2.5A home adapter adds color and light to any room when used with 12 VDC LED lighting strips, or use it with popular Class D and Class T amplifiers and amplifier boards. The included distribution block makes connecting up to four components a breeze.
Part # 129-002
  • Regulated 12V 2.5A power supply
  • Common 2.1 x 5.5 mm plug tip
  • Built-in short circuit protection
  • Includes switchable 4-port power distribution block
  • Mounting hardware included
Streetglow's OPTX regulated 12 VDC 2.5A power supply with distribution block is perfect for powering your 12 VDC LED lighting products at home using 110 to 220 VAC. The Streetglow home adapter, when used with LED lighting strips, adds a splash of color and light to bedrooms, living rooms, home theater rooms and man caves. This adapter comes complete with built-in short circuit protection for piece of mind, a flip-down Edison style plug, and a ferrite bead for EMI and RF interference rejection. Save over $25 (over half) off the regular retail price through this factory buyout. Supplies are limited!
Included is a sleek and compact, switchable four-port distribution block. Built-in, screw-down positive and negative terminals offer quick, secure connections. Adhesive backing has been added to the distribution block, as has two mounting screws, for permanent installation.
Power supply specifications: • Power output: 12 VDC, 2.5A, 30W • Power requirements: 110-120 VAC, 0.5A Max • Plug tip size: 2.1 mm x 5.5 mm x 12 mm • Cord length: 9 ft.
Distribution block specifications: • Dimensions: 3-1/8" L x 2-1/2" W x 7/8" H • Input jack: 2.1 mm x 5.5 mm.
Note: Designed for indoor use only. Do not exceed the current capacity of the power supply. The distribution block ports are wired in parallel. Each port is supplied 12 VDC when connected to the power supply.
  • DC Output Voltage12V
  • Current Capacity2200 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.1 x 5.5 mm
  • Input Voltage100~240 VAC
  • BrandFactory Buyouts
  • Part Number129-002
  • UPC798696169308
  • Product CategoryAC/DC Power Adapters
  • Weight0.85 lbs.
View similar products to the Streetglow OPTX 12 VDC 2.5A AC Adapter Power Supply with Distribution Block
in the AC/DC Power Adapters product category.
