Stanton STR8-150 HP Super High Torque Digital Turntable Straight Tone Arm
Brand:|Model: STR8-150|Part # 245-900
The straight tone arm STR8-150 by Stanton was built with the world's strongest torque motor of more than 4.5 kgf-cm, making it quite the competitor.
ORDER TODAY
Ships in 7-10 Business Days
List Price$999.00
You Save40%
$599.00
Part # 245-900
  • Worlds strongest torque motor (4.5 Kgf-cm)
  • Heavy duty steel construction
  • Ultra stable platter and tone arm
  • Includes Stanton 680HP cartridge
  • Start/brake speed adjustment
  • Digital output [S/PDIF] plug straight into CD-R or computer sound card
  • Key correction
In creating the STR8.150, Stanton went back to basics and re-engineered everything. This "no nonsense" turntable has everything professional DJs need, and nothing they don't. That's why the STR8.150 ("skip-proof" straight tone arm) was built first, and foremost with quality in mind. The STR8-150 offers durable construction designed to minimize feedback, industry-leading torque motor - up to 4.5 Kgf-cm, and an ultra-stable platter and tone arm. And with features like Key Correction, Reverse, up to 50% pitch adjustment, and S/PDIF digital outputs - the STR8.150 is a strong contender for the title of Turntable Supreme.
Specifications: • Starting torque: >4.5 kgf-cm • Motor direct drive: 16 pole, 3 phase, brushless DC motor • Turntable platter: 332 mm diameter Aluminum die-cast • Pitch controls: ±8%, ±25%, ±50% • Wow and flutter: <0.1% WRMS (JIS WTD) with 33-1/3rpm • Braking system: Electronic brake • S/N ratio: >60 dB • Channel separation: >15 dB • Tone arm type: Static balanced straight tone arm with Cardan's suspension and detachable headshell • Effective arm length 194 mm • Tracking force range: 0-3 g • Applicable cartridge weight: 13-18 g • Channel balance: Within 2.5 dB at 1 kHz • Needle pressure range: 2-5 g • Dimensions: 450 mm W x 353 mm D x 146 mm H • Weight: 16.4 kg.
  • Drive TypeDirect Drive
  • BrandStanton
  • ModelSTR8-150
  • Part Number245-900
  • UPC049292550701
  • Product CategoryTurntables
  • Weight36.2 lbs.
View similar products to the Stanton STR8-150 HP Super High Torque Digital Turntable Straight Tone Arm
in the Turntables product category.
