Stanton SC SYSTEM 3 Controller Package with Traktor LE
Brand:|Model: SCS3PAK|Part # 245-916
Stanton SC SYSTEM 3: simply the most innovative, completely mobile MIDI control solution available for today's demanding DJ.
Part # 245-916
  • Unparalleled Plug and Play MIDI control rig
  • Built-in powered USB hub and magnetic connecting system
  • Scalable interface with unmatched portability
  • StanTouch offers easy scratching, scrubbing and navigating of digital audio
  • Control samples, pitch, effects, cue and loop points, and other mappable functions
  • Multiple finger touches can prompt quick kills on EQs or transform effects
Frequently Bought Together
Featuring two completely touch-sensitive control surfaces, the SCS.3d and the SCS.3m, this system brings you intuitive, totally customizable software control without sacrificing any of the features of your traditional DJ rig.
The Stanton SC SYSTEM 3 consists of two decks (SCS.3d) and a mixer (SCS.3m) that have many of the same familiar controls as a traditional two turntable and mixer setup, however, they are far more powerful and advanced. At a fraction of the size and weight of a traditional setup and with minimal moving parts, the SC SYSTEM 3 is an excellent platform, regardless of whether you're a seasoned veteran or a budding DJ.
The SCS.3 controllers can all be used separately or together to give you an unparalleled MIDI control rig that allows you to plug and play anywhere in the world within minutes. With a built-in powered USB hub and magnetic connecting system, the SC SYSTEM 3 controllers can be easily connected to each other for a high tech version of a full traditional DJ setup - without the weight, size and connectivity issues.
Four Deck Control
The SCS.3m features two channel strips for control of two channels of a software mixer at any one time. However, each channel strip can be switched to control an additional two channels for a total of four channels of control with the 3m, providing a scalable interface while remaining portable. When switching between decks the 3m will remember which control mode each deck was in (FX or EQ), and will automatically update the sliders to that channel's last settings.
See Me, Feel Me
The SCS.3d’s layout and portability provide DJs with an unmatched level of performance and control. The StanTouch® interface can be used for scratching, scrubbing, and navigating through digital audio. The tactile buttons, triggers, and virtual faders can also control samples, pitch, effects, cue and loop points, and other functions which can be easily mapped. Multiple finger touches can even prompt quick kills on EQs or transform effects on volume.
USB Hub
The built-in powered 4-port USB hub can be used to connect additional SCS.3 products to the SCS.3m allowing a single USB cable to be connected to the computer. With 2 ports on the rear of the unit it is possible to connect devices very quickly for fast setups in mobile environments. Two additional ports on the inside of the back panel of the SCS.3m allow cables to be routed from additional 3 Series controllers or storage devices such as flash drives. With a power connection, the USB hub ensures that devices receive enough power for complete stability in any performance environment.
Hook Me Up
Magnetic connection system allows multiple SC SYSTEM 3 units to securely snap together, creating a larger control surface with increased performance options, and built in wire management means there won't be a mess of cables to deal with.
USB Specifications:
USB 1.1 and 2.0 class compliant MIDI controller
USB bus-powered*
Power Requirements:
12V DC / 1500mA
Minimum System Requirements:
Mac: Power PC G5 or multicore Intel® processor Mac OS X (v10.4 or later), Intel Core Duo 1.66 GHz, 1 GB RAM
Windows: XP (SP2, 32 Bit) or Vista (SP1, 32 Bit, 64 Bit) Pentium IV or Athlon 1.4 GHz (SSE1), 1 GB RAM
(Internet connection required for software activation and updates)
Form Factor:
Dimensions for each SCS.3 component (H x W x D): 8.52" x 4.72" x 1.38" (216.5 mm x 120 mm x 35.25 mm)
Dimensions for the entire SC SYSTEM 3: 8.52" x 14.16" x 1.38" (216.5 mm x 360 mm x 35.25 mm)
Weight:
SCS.3d: 1.10 lbs / 0.499 kg; SCS.3m: 1.16 lbs / 0.526 kg
*USB hub/port must meet USB power specification; when internal USB hub is used, additional power must be supplied to unit.
  • BrandStanton
  • ModelSCS3PAK
  • Part Number245-916
  • UPC049292002484
  • Product CategoryDJ Controllers
  • Weight6.55 lbs.
View similar products to the Stanton SC SYSTEM 3 Controller Package with Traktor LE
in the DJ Controllers product category.
