Stahl Tools TCSS Temp Controlled Soldering Station ESD Safe
Brand:|Model: TCSS|Part # 374-200
The Stahl Tools TCSS electronic controlled soldering station is adjustable within a range of 300°F to 840°F, and its ESD-safe design makes it a great tool for precision solder work on and around electrostatically-sensitive components.
List Price$79.99
You Save26%
$59.50
Buy 5+$54.75
Part # 374-200
  • Electronic control of the unit's heat from 300°F to 840°F
  • 48 watt ceramic heating element
  • Super-slim ESD safe pencil iron
  • Ceramic ringed stand can attach to the base or stand alone
  • LED indicator shows when the heating element is active
The Stahl Tools Electronic Controlled Soldering Station is designed for production soldering and to meet the daily demands of the electronics professional. The TCSS offers electronic control of the unit's heat from 300°F to 840°F at 48 watts through the ceramic heating element, and is adjusted easily by the front panel's temperature control knob.
With the TCSS's super-slim ESD-safe pencil iron and included 1.5 mm conical tip, you can work confidently on or around sensitive components. Operate the iron while the ceramic ringed stand is attached to the base unit, or detach the stand when space is limited. Heat output is controlled by the dial marked in °F, and an LED indicator shows when the heating element is active. Replacement soldering tip: Stahl Tools TSRT. Replacement soldering iron: Stahl Tools DDRI.
  • BrandStahl Tools
  • ModelTCSS
  • Part Number374-200
  • UPC844632089046
  • Product CategorySoldering Stations
    (34 Reviews)
  • Weight4.35 lbs.
View similar products to the Stahl Tools TCSS Temp Controlled Soldering Station ESD Safe
in the Soldering Stations product category.
Stahl Tools TCSS Temp Controlled Soldering Station ESD Safe is rated 4.4412 out of 5 by 34.
Rated 3 out of 5 by from Mixed feelings on this one.I bought this in Nov of 2013. A few months ago the iron died. Not a big deal. A year and a half isn't bad on an iron in this price range. I ordered two replacement irons with matching tips. (I'm a semi-pro guitar tech.) They were back ordered, so I was stuck with using my cheapo RS iron for awhile. My bad. I should have ordered the replacements when I bought the station.But here's the rub . . . both replacement pencil irons failed to provide temp feedback. Both, immediately went to full power regardless of the temp setting. Needless to say, both units burned up on first use. I hope PE will exchange these for me, but it does make me a little trigger shy for this unit. I could see maybe one iron defective, but both?By the way, I have no doubts about PE exchanging these. They've always provided excellent customer service.
Date published: 2015-09-28
Rated 5 out of 5 by from Great for my NeedsHi all. Bought this about 1 year ago. Have only used it a few times. But seems to work Great for my needs. Usually working on a car. Used it for soldering the power wire for my tow harness. Soldering 4 pairs of 18 gauge speaker wires to the factory harnesses inside my Tucson. Cord is long enough to allow me to do that. Even soldered a piece of 12 gauge speaker wire to the terminal cup of an automotive subwoofer box. That was a bit tricky.
Date published: 2015-08-13
Rated 5 out of 5 by from Great station for the money!!This is a great station for the price, good quality, holds stable temp.This is "almost identical" to the Weller WES51 I have at work, and costs far less.(I know, I took them both apart to see) lol Be sure to order the extra tips.The irons' strain relief might become an issue under heavy use, but easily resolved(use your imagination) Great buy!!
Date published: 2015-01-20
Rated 5 out of 5 by from Review TitleThis is a great station for the money! I'm rough on all of my tools so I'm actually about ready to buy my second unit.
Date published: 2015-01-12
Rated 5 out of 5 by from Nice unitI purchased this product about a month ago, nice , very nice unit . For the price ,ya can't beat it. Seriously !! I had been looking(researching actually) soldering stations for awhile . The price of other stations is what kept me looking . I'm glad I did ! It led me here . So to anyone else out there "looking" , look "No FURTHER " !
Date published: 2014-12-23
Rated 4 out of 5 by from Good little solder stationI purchase this stahl when it was a sale and I don't know much about this brand tool I have to say it works very well and heats fast so over all with the price I purchase extra tips and these tips are coat for long life if you care for them right like keep them tinned and when not in use turn your heat down or turn off high heats for long periods will damage tips. The reason I gave 4 stars is the company could spend alittle extra and put a digital control temperature control on it. But don't get me wrong it works very well just like it is.I would recommend this tool to anyone!
Date published: 2014-11-24
  • 2016-02-06T06:27CST
  • co_hasreviews, tv_0, tr_34
  • loc_en_US, sid_374-200, PRD, sort_mostRecent
I bought this station 3 years ago, now it stopped heating, with the dial at 46 the light blinks, but no heat, with the dial at more light is steady, but still no heat, use aprox. 3 hours a week.
Asked by: Mexking
Date published: 2015-04-20
does it have a ground
Asked by: Danys
Yes.
Date published: 2015-02-23
The instructions for the TCSS state that the LED will illuminate while the iron is heating and turn off when the set temperature is reached.  The LED light on the TCSS unit we purchased simply blinks.  Is that correct?  Thanks.
Asked by: Yosso
Yes the blinking LED is normal behavior for these soldering irons.
Date published: 2014-12-31
I just received the TCSS Temp Controlled Soldering Station. When I turn the station on to lower temps, the Red Lamp indicator blinks immediately but the Iron does seem to heat up. Is this normal behavior?
Asked by: Dbunny
Yes this is normal behavior for this station.
Date published: 2014-12-18
I'm a beginning electronics hobbyist about to undertake the restoration of a 1960s jukebox. Is this soldering iron a good fit for a beginner? Thanks.
Asked by: promano3131
Yes this will work well for a beginner.
Date published: 2014-12-08
I bought one of these units about 7 months ago and just recently my iron has not been heating at all. I would like to know if there is a way for me to fix it or if I should get a replacement.
Asked by: Parker0123
This is something we will exchange under warrant. Please call or email our tech department for help with this, 800-338-0531 x1 or tech@parts-express.com.
Date published: 2014-06-20
  • 2016-02-06T07:32CST
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_374-200, PRD, sort_recentQuestionsFirst
Videos
