Stahl Tools SSVT Variable Temperature Soldering Station
Brand:|Model: STSSVT|Part # 374-100
The Stahl Tools SSVT variable temperature soldering station was designed to exceed the expectations of veteran technicians -- at a price that's appealing to the electronics hobbyist.
List Price$21.99
You Save11%
$19.54
Buy 5+$18.57
Part # 374-100
  • On/off switch with "power-on" indicator light showing when the iron is hot
  • Variable 302°F to 842°F heat setting to match specific soldering needs
  • ETL certified for safety and performance
  • Cushioned rubber grip for extended comfortable use
  • Replaceable tips provide additional functionality
  • Quality performance at a discount price
Make connections that last! A Stahl Tools SSVT variable temperature soldering station provides the adjustability demanded by professionals, but offers it at a price that enables anyone to solder better. Total control over a soldering iron's heat is one sure way of making perfect electronic terminations every time, no matter the job's size.
Many different soldering tasks are accomplished easily by using the SSVT's adjustable 5 to 40 watt (150°C to 450°C temperature) adjustment. The lightweight pencil design features a fatigue-reducing rubber grip, and a Bakelite-ringed holder keeps the iron at the ready. A field replaceable, precision ground, iron-plated solid copper tip provides maximum heat transfer, minimizing cold solder joints. Includes 1.5 mm conical soldering tip and cleaning sponge. Additional tips available for a variety of soldering applications. Stahl Tools—The Technician's Friend™.
Tip Replacement and Dressing:
Tip replacement or cleaning should be done only when the iron is at room temperature. The tip can be changed or replaced simply by unscrewing the knurled nut from the barrel assembly. The station must be switched off and allowed to cool before and during this operation, as damage may result if the system is left on without the tip installed. After removing the tip, blow out any oxide dust that may have formed in the tip retaining area of the barrel. Be careful to avoid getting debris in your eyes. Replace the tip and screw the retaining knurled nut onto the barrel assembly; tighten only finger-tight. To avoid burning your fingers, pliers should only be used to tighten the nut if it becomes loose when the iron is hot. Care should be taken not to overtighten, as this can damage the element.
General Cleaning:
The outer case of the iron or station may be cleaned with a damp cloth using a small amount of liquid detergent. Never submerse the unit in liquid or allow any liquid to enter the case of the station. Never use solvent to clean the case.
Maintenance:
The iron should be placed in its stand when not in use. If the supply cord becomes damaged, it must be replaced by a qualified service technician.
  • BrandStahl Tools
  • ModelSTSSVT
  • Part Number374-100
  • UPC844632077272
  • Product CategorySoldering Stations
    (196 Reviews)
  • Weight1.75 lbs.
View similar products to the Stahl Tools SSVT Variable Temperature Soldering Station
in the Soldering Stations product category.
Stahl Tools SSVT Variable Temperature Soldering Station is rated 4.2908 out of 5 by 196.
Rated 4 out of 5 by from Decent performance given the low priceThis unit looks very similar to a Weller soldering station I bought back in the 90's. That unit worked better, but died with only a modest amount of use.This station gets the job done - eventually. My biggest complaint is the extended warm up time. I purchased the set of tips for this station and realized that those tips weren't well tinned out of the box. Therefore I did an initial tinning on them and found that I had to have the temperature dial about 75% and still it took several minutes before reaching the melting point of the solder. Once up to temperature, the unit works fine. The other negative is the cord used for the iron - it's pretty much the same as the power cord (thick vinyl jacket) and thus quite stiff. Given the under $20 price one has to temper their expectations. The last solder station I used (it's been a few years) was a Hakko unit and this Stahl is nowhere near that quality.
Date published: 2016-01-06
Rated 5 out of 5 by from If you are J-Standard this will last YEARS!Have wellers and got this years ago... still works and still using the same TIPS!!!!!! got a few 4 packs of tips..... still never had to replace any.....
Date published: 2015-12-01
Rated 4 out of 5 by from can't complain for the price, it works greatI bought this item to solder wires in my hot rod and it works just fine
Date published: 2015-10-29
Rated 3 out of 5 by from Great, except for!!!Purchase my first one about a year ago. This item works well, preformed very well for the serious hobbyist. But to the problem, at least for me. The knurl nut is to close to the tip. This brings it into contact with sponge or other medium used to clean the tip. The tip cracked into pieces. I asked PE for a new knurl nut and none available and never will be. They sent me a whole new unit, crazy right? Oh sure great customer service, but???
Date published: 2015-09-06
Rated 5 out of 5 by from Worked very wellThis is my first unit of its type and I was very please with the results from its first use. I have typically only had the small 5W hobbist type and a cheap 180W gun type but I can barely get them to melt the solder. This was worth the investment for my occasional use. I would recommend this to any of my hobbyist friends.
Date published: 2015-05-30
Rated 4 out of 5 by from Buy the Extra Tip Kit While You're HereThe conical tip that comes with ANY soldering iron is useless for 9 out of 10 soldering projects. Get the additional tip kit for this set (http://www.parts-express.com/stahl-tools-ssrt-4-piece-soldering-tip-kit-for-stssvt--374-102) while you're here. It contains a chisel tip that you'll wonder how you ever did without.I would concur with other posters who beefed about the heat - you have to crank it up pretty high on the dial to melt the nice solder you purchased at the solder store and it's pretty rough trying to remove that solder applied by the Chinese manufacturing machines.
Date published: 2015-03-05
  • 2016-02-08T06:13CST
  • co_hasreviews, tv_0, tr_196
  • loc_en_US, sid_374-100, PRD, sort_mostRecent
How long is the station to iron cord?
Asked by: Jlpnjjp
Does anyone know the Output voltage to soldering iron? Is it 24v or 110/120?
Asked by: JustSomeOldDude
can this be used with 220-240 volt ?
Asked by: Muhammed
This is 110-120V only.
Date published: 2016-01-18
can this be used for wood burning?
Asked by: kristy75
I don't see why not, although we do not offer wood burning tips for this model.
Date published: 2015-12-04
Stahl Tools SSVT Variable Temperature Soldering Station. Do you sell the replacement tips for this model as well? And is there a assortment?
Asked by: joncravens
Yes we do have an assortment of replacement tips available for this station:http://www.parts-express.com/stahl-tools-ssrt-4-piece-soldering-tip-kit-for-stssvt--374-102
Date published: 2015-10-30
What tips are available for this station?
Asked by: Frank99
The tips available for this station are below.http://www.parts-express.com/stahl-tools-ssrt-4-piece-soldering-tip-kit-for-stssvt--374-102
Date published: 2015-09-09
  • 2016-02-08T07:05CST
  • co_hasquestionsanswers, tq_23
  • loc_en_US, sid_374-100, PRD, sort_recentQuestionsFirst
Videos
