Stahl Tools DDSS Digital Display Soldering Station
Brand:|Model: DDSS |Part # 374-300
Professional results from a temperature controlled soldering station. Use the Stahl Tools DDSS on even the most sensitive components.
List Price$129.99
You Save39%
$79.50
Buy 5+$75.53
Part # 374-300
  • LCD indicates temperature pre-set and actual temperature
  • Variable heat setting (normal): 215°C to 300°C (419°F to 572°F)
  • Variable heat setting (production line): 320°C to 380°C (608°F to 716°F)
  • Super-slim ESD safe pencil soldering iron
  • Includes base, holder, and cleaning sponge
The Stahl Tools DDSS Digital Display Soldering Station is designed for production soldering that meets the daily demands of the electronics professional. It features a 48 watt ceramic heating element with a 3-1/2 ft. power cord that can heat up quickly to 400°C.
With a super-slim ESD safe pencil iron tip that measures 3", and a 4-1/2" handle, you can work confidently on or around sensitive components. The ceramic ringed stand can be attached to the base or detached if space is limited.
Temperature control up/down buttons provide precision heat management. Operating temperature is shown on the 2-1/4" x 1-1/8" LCD display.
Tip Replacement and Dressing: Tip replacement should always be done only when the iron is at room temperature. The tip can be changed or replaced simply by unscrewing the knurled nut from the barrel assembly. The station must be switched off and allowed to cool before and during this operation, as damage may result if the system is left on without the tip installed. After removing the tip, blow out any oxide dust that may have formed in the tip retaining area of the barrel. Be careful to avoid getting debris in your eyes.
Replace the tip and screw the retaining knurled nut onto the barrel assembly; tighten only finger-tight. Pliers should only be used to tighten the nut if it becomes loose when the iron is hot to, avoid burning your fingers. Care should be taken not to over tighten as this can damage the element.
General Cleaning:The outer case of the iron or station may be cleaned with a damp cloth using a small amount of liquid detergent. Never submerse the unit in liquid or allow any liquid to enter the case of the station. Never use solvent to clean the case.
Maintenance: The iron must be placed in its stand when not in use. If the supply cord becomes damaged, it must be replaced by a qualified service technician.
  • BrandStahl Tools
  • ModelDDSS
  • Part Number374-300
  • UPC848864013688
  • Product CategorySoldering Stations
    (2 Reviews)
  • Weight4.3500 lbs.
View similar products to the Stahl Tools DDSS Digital Display Soldering Station
in the Soldering Stations product category.
Stahl Tools DDSS Digital Display Soldering Station is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Very favorably impressedI used this several times. It heats up within a minute or less, seems to maintain the set temperature within 10 degrees F or so (based on the displayed temp vs the set temp), and feels comfortable in my hand. The soldering iron fits the supplied soldering iron holder snugly but not too snugly.Wish I had purchased this many years ago.
Date published: 2015-03-14
Rated 5 out of 5 by from Digital DisplayI love the digital Temp display showing both set point and actual temps. This unit reaches set points above 600 degrees vey fast less than 1 min. I like this unit better than the Weller soldering unit that takes a lot longer to heat up.
Date published: 2015-03-12
  • 2016-02-09T06:14CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_374-300, PRD, sort_mostRecent
How long is the cord from the base to the iron? I have another brand soldering station that I like but the cord is too short to reach all the different areas of my workbench.
Asked by: CameraBob
It features a 48 watt ceramic heating element with a 3-1/2 ft. power cord.
Answered by: GregT
Date published: 2015-12-27
I do not see replacement tips listed. Are they similar to the TCSS tips?
Asked by: electronblue22
The 374-200 TCSS Temperature Controlled Soldering Station and the 374-300 DDSS Digital Display Soldering Station both use the same iron so both can use the 374-202 TSRT tip kit.Also, the 374-302 DDRI Digital Display Replacement Iron will work with both soldering stations.
Answered by: PE Tom
  • 2016-02-09T06:55CST
  • loc_en_US, sid_374-300, PRD, sort_recentQuestionsFirst
